cheap upgrade *fix*
  • Stoopalini
    • 99
    cheap upgrade *fix*
    Ok, we all know that feeling when you need a fix BAD, right? You just need to change something with your setup -- anything!
    Well, Being the cheap bastard that I am , I just bought two Aura Bass Shakers for $8.95 a piece to try and satisfy this urge
    Now I just need something to power them with. The specs state they are 20w RMS and 30w Max.
    So what kind of advice can you guys give me for a cheap amp that pushes 30w x2 at 4-Ohms ?
    Thomas
    Oh, BTW: here's the link to the shakers:
    Shakers
    • 16478
    I also just picked up a set locally for about the same price and mounted them to the Futon this weekend. I'm currently using a single side of my Hafler power amp to push them which is serious overkill but for now its all I have. I'm going to keep an eye open in the pawn shops etc for an old stereo amp or receiver etc to use on them. I'd like it to have a remote so I could control the shake and turn them on or off depending on the mood or material etc.
    • Stoopalini
      • 99
      Hey Andrew,
      Yea, not a bad idea there about the pawn shops. I think I'll hit a few on the way home tonight and see what treasures await me -- LOL.
      Wish me luck
      Thomas.
      mmmmmmm -- I'm thinking Adcom 535 for, oh, $35
      • Lexman
        • Jun 2000
        • 1776
        Oh, so the Great Stoopalini is going to get one for 35 huh? Wait, I Think I know what shop that is. Not if I get there first, haha.
        Good idea on the pawn shops!
        Lex
        <A HREF="http://www.catcables.com" <IMG SRC="http://www.htguide.com/lexman/other/sm_logo.gif"
        • Stoopalini
          • 99
          Well, no Adcom 535 for me --- Lex must have beat me to it! d**n you lex!
          I&#39;ll keep checking back at the pawn shops and hopefully I can find something decent before the transducers arrive, otherwise HT Store here I come --- and we all know how dangerous that can be.
          Thomas.
            • 16478
            Hey I'd better get posting Lex's almost catching up again LOL
              • 16478
              • John Holmes
                • 2707
                Stoopalini,
                Sorry that you missed out on the amp. It was a great deal. In this game more will come along!
                • KennyG
                  Good deal on Bass Shakers!
                  by KennyG
                  Check out the deal on Aura Shakers, complete with amps!!! Now that's cheap
                  15 September 2000, 20:23 Friday
                • Stoopalini
                  Aura Bass Shakers
                  by Stoopalini
                  The Aura Bass Shakers -- Are they worth it?
                  Installation:
                  I flipped over my couch and removed the undercloth by pulling the staples out all the way around. Then I cut two boards that measure aprox 6" x 6" x 1.5" and screwed them to the frame...
                  05 September 2000, 09:48 Tuesday
                  Shakers
                  by TEK
                  I'm wondering about installing bass shackers in my theater.
                  Does anyone have experience with bass shakers that you would care to share?
                  Number of seats, number of shakers, brand, how you drive them and your experience with them.
                  Would you recommend it as a solution,...
                  30 May 2015, 01:09 Saturday
                • storello
                  Too cheap to replace old CDs
                  by storello
                  As an "early adopter" type, I started collecting CDs in 1984. Most of these sound like crap so I've been trying to figure out how to fix my collection without replacing everything. Here are options I'm considering:
                  1) Rip them and fix them up on a PC. This is a daunting...
                  25 March 2006, 13:22 Saturday
                • freon
                  Wiring for Shakers
                  by freon
                  I got some of the Aura shakers 4ohm 25watt.
                  There is six total that I have 1 for each seat.
                  I want to power them with an old H/K reciever in stereo mode its rated at 75watt@80hm or 100watt@4ohm FTC.
                  What would be my best option. I was thinking of wiring Three...
                  03 May 2005, 19:10 Tuesday
