Component video switch
  • NonSense
    • Nov 2003
    • 138
    Looking for links or suggestions for a component video switch. I expect there are several products to fill this nitch of the market.
    Bruce
    • 27460
    look at Parts Express, our sponsor. goodluck.
    • dmcgowan
      HELP - RDV-995 / RSX-1055 Component Video
      by dmcgowan
      I lashed out today and brought home a 42" Plasma
      Rearrange the room, new cables connected, etc etc and everything works fine except for using the RSX-1055 to switch component video from the RDV-995.
      I can direct connect the RDV-995 to the Plasma and get...
      25 October 2005, 08:43 Tuesday
    • Hap C
      Rotel RSP-1066 + Audio Authority 1154 Component Video Switcher - anyone using??
      by Hap C
      I'm considering purchase of a Rotel RSP-1066 pre-pro with 1075 amp, but the 1066 doesn't have enough HD component video inputs for my needs, it only has 2. I've identified the Audio Authority 1154 component video switch as a strong possibility to add to the 1066. The AA has 4 HD component video inputs,...
      16 February 2003, 15:18 Sunday
    • JoeHard
      Help with component video and 1066
      by JoeHard
      I want to connect a dvd player, Xbox, and cable box to my Pioneer tv using component video . The tv has two component ins. I hooked the cable box directly to component input 1 on the tv, and and the component out of the 1066 to the tv's component input 2. Then I connected the Xbox and dvd player to...
      23 January 2005, 20:32 Sunday
    • ghrays
      RSX-1055 Component video inputs
      by ghrays
      I recently changed my video display from a Pioneer elite PROHD510 with multiple component video inputs to a Panasonic 50" plasma HDTV with only one component video input. Therefor, I am using the component video switcher on the Rotel 1055 for the first time, to switch between my progressive scan...
      31 August 2003, 09:05 Sunday
    • SayersWeb
      Workaround for 1066 2 component video input limitation?
      by SayersWeb
      Since getting an HD cable box I have three sources of component video (cable box, DVD, Playstation 2) to use with my front projector system. I've been using S-Video with the PS2, but it does not look anywhere near as good on a 92" screen.
      So, I'm trying to think of a good workaround....
      22 May 2003, 16:00 Thursday
