Optical Issues between TU-DSB20 and 1014-TX Reciever
  • billz260
    • 40
    I bought a TU-DST50 on ebay cheap for the superbowl and everything worked perfectly for the OTA broadcast. Everything except the digital audio. I figured it was the used and abused unit I bought on ebay but now I am borrowing a newer Panasonic TU-DSB20 from a friend and it is having the same problems. Analog stereo works fine. But when I plug in and assign the optical audio the receiver acts funny. The Dobly Digital LED on the screen flashes on and off quite rapidly, kind of like the 'stereo' light on a radio when it is getting a bad reception. It has happend with both of the panasonic OTA tuners and my NEW Pioneer 1014-TX Receiver. I have tried multple input assignments as well as two different types of optical cables, some cheap non insulated (but covered) ones that work fine with my dvd player, a GE cable that is a bit more robust looking but basically the same as any other optical cable.
    I am perplexed, confused and just plain frustraited. Can anyone please shed some light on my problem?
    Bill, could it be your reception? If you are in a bad or null zone it could just be the signal is dropping out enough to disrupt the 5.1, but not enough to drop the other.
    • billz260
      • 40
      It definatly could be that, but I figured that since the picture and analog were there full tilt, that the digi sound should follow. Of course, I am very new to this and don't really know how every works so it is dificult for me to trouble shoot. This weekend I'll play with antenna direction and see if we can pick up some digi sound. I wish I had a signal guage on this unit, maybe that would shed some light. Thanks for the reply.
        Good luck up on the roof. I hope you aren't in a "snow zone". :
        • billz260
          • 40
          Nope, Tulsa, OK. pretty cold but not bad today. Antenna is in the attic, we're on a hill and well withing range of the ant towers, but I will see what we can do...
          • Uncle Clive
            Former Moderator
            • Jan 2002
            • 919
            If you are using a set-top box digi out and is having the same probs. with two receivers, could it be that it is the set-top box that is not sending a clean signal, or, is not assigned "optical out" in the audio menu? Have you tried a DVD player in that receivers' opti. input just to be sure? Jut another thought. :T
            CLIVE
            • billz260
              • 40
              DVD works fine w/ optical. I wish the OTA box had a coax as well.
              I messed with antenna alignment this weekend but no luck, now it's dropping the picture every once in a while. I couldn't get the DD light to go faster or slower, I guess it is just an un-usable signal.
              I still think it could be reception but I don't think I can convince my wife to let me stick the ANT on the back chimney.....
              • billz260
                • 40
                Well, I just got an email from another HT guy that saw this post. I hope he posts.
                He is having the same issue, I don't know what SAT/ANT set up he's using but he has the 1014 too. Does anyone have the 1014 and digital service where the 5.1 is working fine? Curently just using DPLII and stereo input .
                I guess I need to get another 5.1 receiver in to test. I am currently finishing up my rack inserts for the cabinets, So when I pull it all out, maybe I can do the testing then. We watched 24 last night and I was YEARNING for real 5.1....
                • billz260
                  • 40
                  Anyone hear anything new on this?
                  This is what I have gathered from another site someone sent me, maybe one of you HT guru's could shed some light on what might be happening.
                  Apparently some of the newer receivers 'upconvert' audio signals from 48 something to 96 something or other? That is when the DIGITAL signal gets unusable, it's getting sent and something about the upconversion process mixes it up. I heard that maybe a source sending the 96 whatevers to the Receiver so that it wouldn't have to upconver may solv the issure.
                  Thoughts? Stereo is good but Surround is better for shows like LOST and 24.
                  Thanks!!
                  • billz260
                    • 40
                    BUMP
                    NO IDEA'S? I am really a beginner as to how this stuff works. Getting it set up correctly means understanding what everything is doing, and right now I just don't get it.
                    • billz260
                      • 40
                      Still nothing?
                        Comp causes OTA reception issues??
                        by impala454
                        So I am messing around with my second computer, which is currently sitting about 3 ft away from my DLP TV, and about 4-5 ft away from my terk HDTV antenna. I'm sitting here watching football while working on the PC, and noticed that my reception was really getting bad, to the point that I no longer...
                        03 December 2011, 16:54 Saturday
                      • misterdoggy
                        which listening mode for Satellite optic cable reception
                        by misterdoggy
                        What do you think is the best listening mode for optical reception from the satellite. Ie movies, shows, music on Satellite reception.
                        I've been using DPII, but am not sure if something else might be better ?
                        Any advice would be greatly appreciated.
                        The Satellites...
                        02 September 2005, 03:56 Friday
                      • stainless
                        directv hd box used for OTA HD only?
                        by stainless
                        Im looking to buy a small HDTV for a bedroom and I wont be running cable or sat. to it, just antenna. Im looking at a low end TV and the only reason it peaks my interest is the cost and the built in HD tuner. I do have an HD directv box not being used so I was wondering if that box can be used as a...
                        03 February 2008, 12:12 Sunday
                      • J.H.
                        Sirius Radio In House Reception?
                        by J.H.
                        I know off topic for this forum but I am my wits end. I have had Sirius radio in my truck for a few weeks now. I have the sportster sirius radio in my truck and have no problem with reception. I just bought the Sirius sportster SP-B1 boombox and connot get reception at all really. I moved the satellite...
                        19 December 2005, 16:54 Monday
                      • ajpoe
                        Tivo and OTA... please help!
                        by ajpoe
                        I live in Dayton, OH. I am having and issue with my OTA broadcasts. For FOX, my HD Receiver/Tivo (HR10-250) is showing the programming information on 45-1 with no pic/sound. The picture and sound for FOX is being broadcast on channel 30-1 as well but 30-1 has no programming info and just says Regular...
                        01 November 2004, 14:26 Monday
