Playing WAV file/format with DTS encoding on Sony BDP-S5100 Player using DLNA Streami
  • shin
    • Apr 2014
    [Playing WAV file/format with DTS encoding on Sony BDP-S5100 Player using DLNA Streaming]
    Hi all,
    I have PS3 Media Server running on my notebook and I have some WAV file/format with DTS encoding that I would like to play by streaming to my player. At this moment it is not working. Is there anyone who had same or similar problem that can give me a advise.
    Greetings,
    Shin
    • 16199
    Your post is confusing to me, because DTS encoding, like Dolby AC3, refers to a specific kind of multi-channel encoding used for audio files (either standalone or part of a video program), based on a 96 kHz carrier frequency. It's possible a player could generate some type of WAV file output as an intermediate step for playback, but to my knowledge this may not be a standard PCM WAV file playable on any system compatible with .WAV.
    I sugest consulting this guide about DTS encoded playback with an add on to support DTS encoding on standard Windows players. I'm a Mac guy myself, so the tools and players I use wouldn't be of any help to you.
    In this guide we will teach you how to playback DTS-WAV files that could have come from DTS CDs or enhanced audio CDs. Many softwares have issues playing these files back, but luckily there are a few that make it very easy.
    • Kevin D
      • 4601
      DTS CD's were encoded as standard CD's that could be ripped to a WAV file and played back on equipment. Standard 44.1kHz encoding. If the playback device plays the WAV file exactly as it was on the disc, it should decode. My guess is the streaming server is some how compressing the "music" or altering the stream slightly, or the BDP-S5100 is up-converting everything to 48kHz (a problem with a lot of players).
      Kevin D.
      • saurabh
        Convert Stereo Soundtrack -> DTS 5.1
        by saurabh
        But first to check if your 5.1 works fine.....
        http://www.sr.se/multikanal/english/e_index.stm
        Download the last item called "Multichannelcheck" in either DD or DTS. It's in Swedish but that makes no difference, it will do the job.
        Then an additional...
        21 April 2005, 22:23 Thursday
      • wildtangent
        CP 800 DLNA streaming
        by wildtangent
        My music is currently on a D-Link NAS with some other content on a USB external hard disk attached to a Windows 7 PC. JRiver is on the PC as well.
        I have an Android tablet (Google Nexus 7)
        The CP800 is connected by Ethernet to the LAN, USB is not connected.
        JRiver is setup to share...
        07 April 2014, 19:55 Monday
      • mb225
        Is there data loss when converting WAV to AIFF
        by mb225
        I'm cleaning up my iTunes digital music server, getting everything tagged correctly and putting in missing album artwork, etc. When I originally ripped CDs I was ripping them as WAV but switched to AIFF format in iTunes about 1 year ago. So 70% of my music is stored as WAV and 30% as AIFF. The latest...
        31 October 2010, 11:33 Sunday
      • wxmanunr
        Slightly OT:DLNA Client to Feed SSP-800
        by wxmanunr
        Ok, this may be a dumb question. And, it is slightly off topic. But, I want to add a DLNA client to my system that will feed my Classe SSP-800 via HDMI with no sample rate conversion or other messing around with the signal. I'd like to primarily feed CD-sourced FLACs (to get rid of clutter and put...
        21 July 2014, 10:42 Monday
      • augerpro
        Need some .wav's!!!!!
        by augerpro
        Hi all. I have a little program that can add different distortion profiles to a song so you can listen and see how and if it makes a difference. But this program requires a .wav file that is 16 bit, 44.1 kHz, mono, and <60 seconds long.
        So where would find these or go about making...
        18 August 2007, 16:32 Saturday
