Power cables behind drywall
  • ray5
    • 444
    Don't know if this belongs here but are there any power cables available that are rated to go behind drywall that meet building codes?
    Ray
  • Space
    • Aug 2009
    • 118
    ??? You mean, other than the usual Romex type cable used for electrical wiring inside walls? Maybe you could ask more specifically about what you're trying to do.
    • ray5
      • 444
      I have my TV on the wall. The stock power cord is not recommended to be snaked behind the dry wall to hide it away so I am trying to find some third party cord that is rated such. Hope that clarifies.
        • 16877
        Sorry, every code I'm familiar with (and I think it's specified in the NEC, even) says that all high-voltage power lines in walls must be permanently installed and go between J-boxes, installed by a licensed electrician. So there would not be an electrical cord rated to be run in-wall by a consumer.
        • whoaru99
          • 638
          Generally, I think you're supposed to bring the power to the TV by putting a receptacle in the wall behind the TV.
          Here's a kit that doesn't require the homeowner to tap directly into existing wiring. http://www.amazon.com/Rapid-Power-Re.../dp/B0020LOJNQ
          You still have to use Romex, but only inasmuch as you need a piece long enough to connect the male power inlet to the receptacle. Then, the extension cord thing externally connects an existing receptacle to the power inlet, which in turn feeds the recessed TV receptacle though the short length of Romex inside the wall.
          ----JAFFE'S PRECEPT
          • ray5
            • 444
            That's exactly how I have done it. It just offends my sense of esthetics and was wondering in the world of power cords if someone has come up with something I could use. I guess in the long run I'll have to put a receptacle behind the TV. Thanks,
            Ray
            • Glen B
              • 1106
              How about using a cord cover ? You can paint it to match the wall. I use one I bought from Cableorganizer.com to hide my TV cables.
              The Wiring Solution from Lodging Innovations greatly improves the overall quality of your HDTV presentations by eliminating distractions caused by unsightly cables.
