Rotel RB-1090's Power Cord
  • jteoh1
    • 20
    I just picked up a demo RB-1090 amp from a local dealer; it came with what appeared to be a standard U.S. 110V cord. It is a 14AWG32C gauge cord with pentagonal shape end (wall side). I had a loaner from another dealer recently that had a higher grade cord with a rounded end.
    Could someone confirm if I was given a wrong cord?
    I have bi-wired the 1090 with a pair of B&W Nautilus 802s, the sound seems thin on the low frequency end. Not sure if it is the power cord, the unbalanced interconnects, or this demo unit just needs some break-in period... It just sounded a lot better at the dealer show room with N802s. I'm using Denon 5803 as pre/pro and Sony NS755V DVD/CD player with monster cables and interconnects.
    Thanks for your help.
    John
  • DanR
    • 156
    I used to have a 1090 and the 14AWG cord you are describing sounds right. I also tried a $100 specialty cord and it made no difference. I also have the 802's and the bass was thin at low to moderate listening levels. It seemed I had to crank it up to hear the bass. It was very disappointing! Break-in won't do much.
    :B It's all about the MUSIC!!!
    • DanR
      • 156
      Once I hooked up my CJ 2300A the difference was amazing. Bass response even at low levels was breathtaking or heartpounding- you pick which adjective you prefer. After that I tried my Jeff Rowland Model 2 and realized what the difference is between $2k and $6k!!!
      • soundhound
        • Mar 2004
        • 816
        John, what was the dealer using for a preamp? I whole heartedly agree about the line cord not making a difference as manufacturers tend to supply components that will make their gear shine, it's good for sales. As far as break in all 3 of my Rotel components started a little on the tight or "clinical" side if you will and after hours of use they tend to "relax", open up and show you what they are made of. I went from a Yamaha reciever as a pre through my RMB-1075 and when I went to my 1st Rotel Pre (RSP-980) the difference was astounding. I now have a well seasoned RSP-1068 and it couldn't be better at the price point.
        • jteoh1
          • 20
          Electronics to feed B&W N802s
          I found both Dan and soundhound's observations not only helpful, but they are reaffirming at the same time. I'm going to evaluate Conrad Johnson, Jeff Rowland and McIntosh next. I was surprised to learn that the JR Model 2 was only rated at 75 wpc. I guess there is so much more to it than the wattage rating in considering at a good strong amp. More current into low impedance, power bandwidth, and so on play an important role to driving difficult speakers like the N802s.
          BTW, have you any experience with McIntosh MC602 (2-channel 600wpc) or MC402 (2-channel 400wpc) amp in driving N802s?
          I truly think it is time I got rid of my Denon 5803 receiver as pre/pro. I'm going to eval the Rotel RSP-1098 and RSP-1068 with the Rotel RB-1090.
          At the dealer show room, the RB-1090 was connected Ayers stereo pre-amp and Ayers CD player. The combo seemed to drive N802s with lots of air, power, and musicality with tremendous details. However, the RB-1090 seemed to be on a somewhat harsh side in the mid and high frequency response. I really enjoyed the nice clean and powerful bass response though. Overall, I think the Bryston 4B SST tamed the N802s a bit and not as detailed and musical as the RB-1090.
          I also auditioned the Classe CA-2200 with N802S. The CA-2200 seemed a bit warm, recessed and less detail for my taste. To my ears, the Ayers 150W amp lacks the dynamics, fast response and bass slam although it seemed to tame the N802s overall.
          John
          • Kevin97225
            • Oct 2004
            • 74
            Yes, the RB-1090 comes with standard stock cord. It works well. I've tried replacing it with a couple of
            expensive ones but heard no difference at all, so I'm using the stock cord with both RB-1090's now and
            it sounds great.
            I used to have the B&W N803 and biwired with the RB-1090 and the sound was excellent with good bass, but
            the B&W N803 always was a bit short on bass proformace for me than most other speakers I've owned but
            it's something that some B&W users have complained about with the B&W N803 and N804's. I did originally
            listen to the RB-1090 on the B&W N800 & N802 and it definetly didn't lack any bass that my N803 did.
            I found myself mostly using my Klipsch RF-7 reference speakers (biwired with RB-1090 too)
            so I sold the B&W N803 and bought another
            set of Klipsch RF-7, and it's superb with the Rotel RB-1090. The Rotel RB-1090 definetly doesn't lack
            any bass, nor thin with this combo. The bass is very tight, deep, with slamming force that stunds me.
            The RB-1090 sounded great with the B&W N802 when I heard it at the dealers with the bass being deep,
            tight, and with that excellent superb mid range that B&W is famous for.
            The RB-1090 does need some break-in period. It was a little bright and harsh when I first started
            using mine (brand new) and bass was lacking, but after a few days of running many hours each day, the RB-1090
            became very smooth, sudden deep bass, and all signs of bright and harsh completely disappeared, and became
            even more detailed.
            I am using the Rotel RC-1090 pre-amp and Rotel RCD-1072 CD player with the Rotel RB-1090 amp and
            the sound is amazing with this combo with the Klipsch speakers. I do have a Sony CD player and when
            I use it, the sound becomes much brighter and sound becomes more narrow and thin.
            The bass isn't lacking even on low volumes on my system, even some of the reviews say that Rotel got
            that part right, that it sounds great even at low volumes.
            Maybe the difference is in the equipment combo? I know all the Rotel equipment together is doing
            a great job with giving excellent sound. Rotel did a great job between each unit paring.
            • hired goon
              RB-1090 questions
              by hired goon
              G'day,
              I bought a second-hand RB-1090 yesterday, and have a couple of questions:
              • The seller couldn't find the original power cord that came with the amp. I'm currently using a standard power cord. Is this adequate, or did the 1090 come with a higher quality power cord? Does
              21 January 2005, 05:03 Friday
            • auburnu008
              Help please! - Firmware Upgrade Cord for 1098
              by auburnu008
              Hello all,
              About 2 months ago I got a 1098 used on audiogon. I LOVE IT! In Dec. I got a 1090 and 1095. Well I am VERY happy with them also. I do have a problem though. My 1098 firmware has never been updated and I am planning on doing it. I never got the cord to hook up the 1098 and computer...
              07 January 2005, 01:24 Friday
            • Tapesh
              Power issue with RB-1090 ? Help Please
              by Tapesh
              There is continuous a krrrrrrrrrrrrrrrr. sound coming from my speaker. Possibly power related issue.
              Connections CD Player Sony 555ES -> ASL AQ2004DT -> Rotel RB-1090 -> Polk Lsi9 Speakers
              Sound level increases as connections are made. Just speakers hooked on,...
              13 November 2003, 12:49 Thursday
            • xixel
              RC-1090 Headphone jack
              by xixel
              Ok, so I bought a used pre\power amp, everythings been working great - LOVE the rotel gear, I use my headphones often, without a headphone amp handy I've just been plugging it into my preamp (RC-1090)
              I'm using Beyerdynamic DT-250's (80ohm version)
              For weeks it was fine,...
              12 January 2006, 04:10 Thursday
            • bbutler
              Processor & Amp for 802s,804s & HTM1?
              by bbutler
              I know this is the b&w forum, but I figure you folks might now what is a the best match for my speakers. If this poor forum, I sorry. I'm a newbee
              I'm in the processing of selecting an processor/amp for my home theater.
              I currently have the B&W 802's, HTM-1, 804's (rear),...
              08 June 2004, 22:47 Tuesday
