1095 power cord...
  • H.Donald
    • 477
    1095 power cord...
    I have been trying to find my original power cord that came with my 1095.I have switched cords and cables so many times over the years,I don't remember whats what.
    If anyone knows or is using the original power cord,please answer me this....
    was the oridginal cord two prongs or three with the ground pin.
    Thanks...
  • ht_addict
    • Dec 2002
    • 508
    Believe it was 3prong.
    • Kevin D
      • 4601
      Mine's 3 pronged.
      Kevin D.
      • H.Donald
        • 477
        Oh well,guess I don't have it then....thanks.
        • Dmantis
          • 1036
          Selling it?
          • H.Donald
            • 477
            No...I was thinking of purchasing one of those removable ground pin power cords.
            And today I wanted to use a cheater plug to see if it would remove the hum I have been getting latley....but could not get the cheater on the current power cable that I use.So I went looking for the original cord and could only find two pronged cords in my storage.Hence,my question.....
            But should I ever sell....would probably list here.
            • ht_addict
              • Dec 2002
              • 508
              Just use one of your 2prong powercords and see if the hum goes away. No need for a cheater plug of ground removable powercord. If your getting a hum, try these two things. 1. Remove your tv/sat cable from the the tv and see if it goes away. If it does, if you have a power conditioner or surge bar with a tv coax hookup run it into this first before into the tv. 2. Replace your digital coax hooking your dvd and cable/sat box to your receiver with optical cables and see what happens. When I had a 1095, I had a hum issue and doing these two solutions solved it, especially running the tv coax cable through my power conditioner.
              • H.Donald
                • 477
                Thanks,all the video including the cable box is on one side and all audio is on the other.
                The only connections from dvd and cable box to the processor are...analog and optical audio cables.
                One side has a 5100,the other a 3500......I have not run the cable box thru it....but will give it a try.
                • Cyclesberuff
                  • 42
                  You should try to call Rotel for a replacement. I lost the Powercord on a rb1070 so I called Rotel and they sent me one for a reasonable price. As fate would have it, as soon as the replacement arrived, I remembered where I put my cord.
                  I'm glad Rotel was there to call, they have also sent me replacement fuses for the rb1080. So far I'm satisfied with thier customer service. Good luck!
