Suggestions for HT Surround Sound Processor
  • britrover
    • 14
    I’m looking to add a separate Surround processor for my HT set up. Currently my fronts L + R are powered by McIntosh MC 7200, the center channel and surrounds + subwoofer are hooked into the Harman Kardon AVR 235. The HK is acting as a part processor and part amp as well.
    I’m just beginning to look at processors and so far have B&K and Rotel on my list……………any suggestions on other brands I should look at also I listen to a lot of music so would like something that matches well with my McIntosh. I do want to get a processor that has 7.1 capabilities and can be used with SACD and DVD A
    Any direction / suggestions would be much appreciated
  • Azeke
    • Mar 2003
    • 2123
    What is your SSP budget?
    Azeke
      Twin Moderator Emeritus
      • 16706
      Yeah budget will go a LONG way of dictating which pre/pro to get. Though frankly with things like HDMI switching, room correction, new Dolby formats etc coming out... I'd likely stick to a "budget" pre from the likes of Outlow, Rotel, Sherwood Newcastle, Nad etc. until those features arrive on the next generation units.
      • Shane Martin
        • 2852
        Aud,
        The Sherwood has HDMI switching(coming via an external HDMI box) and Room Correction. Easy choice there.
        Another interesting choice is the Arcam which runs around $2100 US. I assumed that when you mentioned the B&K and Rotel, you were in that range.
        • britrover
          • 14
          Range is up to $2.5K. I'm keen on getting a musical processor that is warm sounding ,pairs well with my McIntosh amplifier and also sounds good for HT.
            • 16706
            Yup Shane that's why I mentioned it However, there's still the new Dolby format coming and a breakout box is a good compromise/solution but it is a compromise. I just wouldn't spend much more than a couple grand personally at this time. The Sherwood would certainly be on my short list though :T
            • britrover
              • 14
              Thanks for the input so far……I did some research and am looking at getting a used Krell, Parasound, TagMclaren or Sunfire probably 5.1 set up as I really don’t have space for a 7.1 set up currently.
              I'm leaning towards a used Krell 5.1 processor or a Sunfire Theatregrand Any thoughts on which will be more musical pre-map to be paired with the McIntosh.
              Cheers
              • gd
                • Jan 2003
                • 583
                Used Krell, huh?... that suggests you favor audio quality over the latest HT features.
                Perhaps in a league with Krell -- and at the outermost edge of your budget -- is the Cary C6... haven't heard it myself, but the few reports I've seen on other forums are very enthusiastic.
                Arcam is excellent -- and very flexible -- for $2K, you could use their loaded receiver as a pre/pro.
                And frankly, as a solid music machine, I wouldn't dismiss the Rotel out of hand, either.
                At that price point, try to audition at home if you can.
                greg (gd to you)
                Frank Zappa
                • Azeke
                  • Mar 2003
                  • 2123
                  There is a gentlemen in the Pawnshop selling his RSP 1098 within your budget.
                  • MilesD
                    I need some amp and processor suggestions
                    by MilesD
                    I'm looking to build a new home theater. I would like to have a 7.1 surround. I need some opinions on this set up. This is what was suggested to me:
                    2 B&W 802D (Left Right)
                    1 B&W HTM1D (Center)
                    4 B&W DS8S (Surround)
                    2 JL Audio f113
                    3 Rotel RB-1092...
                    21 February 2008, 12:57 Thursday
                  • baldgeorge
                    Help - Do I need a Processor for my Amps?
                    by baldgeorge
                    I NEED HELP.HAVE A RA931 AMP,RTC940AX TUNER, RCD950 CD PLAYER AND HERE`S WHERE THE PROBLEM STARTS. JUST BOUGHT A 980 RDA DIGITAL SURROUND ADAPTER.I`M GUESSING I NEED A PROCESSOR TO GET SURROUND.BUT AM I CHASING MY TAIL? WILL THE COMPONENTS I HAVE ALLOW ME TO HAVE A SURROUND SYSTEM.IF SO HOW AND IF NOT...
                    23 November 2004, 22:09 Tuesday
                  • earwit
                    Pre-Amp Processor Suggestions
                    by earwit
                    Well the way I see it, Amps and speakers only change a small degree over
                    time, Pre-amps in the digital domain are always changing.
                    I'm looking from a pre-amp that takes HDMI into account. If
                    you like it or not I beleive the future is HD-Dvd and Blue Ray.
                    They will...
                    17 June 2006, 13:23 Saturday
                  • Alantino
                    How to use a Digital signal processor to create surround sound?
                    by Alantino
                    Hi everybody,
                    I'm new here and had some problem on surround sound system.
                    Actually what is a surround sound system??
                    Is 3D sound different from surround sound?
                    If i to connect my PC sound card output to my digital signal
                    processor(*only 2 output channel),...
                    15 March 2007, 05:32 Thursday
                  • servicetech
                    Surround Speaker project
                    by servicetech
                    I'm planning on building some surround speakers that will be mounted where the wall and ceiling meet. The wall is 10' high, the room is 20' wide. Primary seating area is in the middle, against the back wall.
                    1: I want to make the enclosures angled at the front so the sound won't be shooting...
                    03 April 2008, 11:08 Thursday
