How to use a Digital signal processor to create surround sound?
  • Alantino
    • 3
    Hi everybody,
    I'm new here and had some problem on surround sound system.
    Actually what is a surround sound system??
    Is 3D sound different from surround sound?
    If i to connect my PC sound card output to my digital signal
    processor(*only 2 output channel),
    is it capable of giving me a surround sound?
    Is there any recommended website to readup as i'm quite interested.
    Thanks. :B
    Surround sound is discrete channels encoded separately.
    3d sound is usually an applied processing thing that makes sound come from all your surround speakers in such a way that there is some vague sense of 3d space - though perhaps very wrongly. It's use is fairly limited n my experience.
    Your DSP manual will tell you if it can accept 2 channel analog and do its thing. Unless I'm hearing that your DSP only outputs 2 channels, in which case no - surround means ya gotta have surround outputs.
    • Alantino
      • 3
      Thanks cjd,
      Do u have any recomended website where they teach u how to create surround sound?
      • Davey
        • Jan 2003
        • 355
        A simple, crude "ambience-type" four-speaker system can be programmed with a DSP unit without too much trouble. You'd need to create a L-R signal by polarity-inverting one channel and then summing with the other.
        Apply a delay of about 10mS to the L-R signal and send it to one of the rear speakers.
        Apply a delay of about 20mS to the L-R signal and send it to the other rear channel.
        This is a bit fancier version of the scheme used by David Hafler many years ago. Google.
        The simple "surround" modes available on a typical preamp/processor are implemented with this same basic process.
        However, as Chris noted, true surround sound is only achieved with (separate) discrete channels.
        Cheers,
        Davey.
        • Alantino
          • 3
          Cheers,
          Davey.
          Hi Davey, thanks for the reply.
          If my processor input is a 2 channel audio source, will i still be able to achieve surround sound(discrete channels) with a DVD-Audio source [Quad(4.0)]?
          What i intend to do is to use 2 processor(total of 4 channel) for my Surround L+R, center and rear channel.
