I NEED HELP.HAVE A RA931 AMP,RTC940AX TUNER, RCD950 CD PLAYER AND HERE`S WHERE THE PROBLEM STARTS. JUST BOUGHT A 980 RDA DIGITAL SURROUND ADAPTER.I`M GUESSING I NEED A PROCESSOR TO GET SURROUND.BUT AM I CHASING MY TAIL? WILL THE COMPONENTS I HAVE ALLOW ME TO HAVE A SURROUND SYSTEM.IF SO HOW AND IF NOT ANY SUGGESTIONS.I,M BUILDING A SYSTEM AND HAVE TWO b&W SPEAKERS AT THE PRESENT.
Help - Do I need a Processor for my Amps?
Tags: None
Yes, you will need a pre/pro. Example: RSP-980 or one of the similar preamp/ processors. I would assume your'e RA-931 is an integrated amp? If so you have 2 channel only capabilities even with your'e RDA-980. I had entered into Rotel with their RSP-980, RDA-980, and RDA-985. The current surround processors are hard to beat although the RSP-980 had analog 2 channel that was hard to beat.- Bottom
by formicaI've got a RSP980 prologic preamp and have been using the 6 channel analog input with my DVDA player. My question has to do with how the preamp deals with the LFE output in different modes, particularly in the 6 channel bypass mode. The reason being that if I adjust my sub level using the integrated...-
Channel: Club Rotel
by Aussie GeoffHi,
Thanks to Glenn, Club Rotel members were made aware of an interesting article by Brian Florian in the “Secrets of Home Theatre and High Fidelity” Web site titled “The Secrets SSP (Surround Sound Processor) Benchmark Specifications”.
The link to the article is http:...-
Channel: Club Rotel
by JonMarshWhen I got the email with Trond-Erik's new Pro-Pro, something about that rang a bell. The bell was related to an AV Forums post by a guy with high sensitivity speakers comparing the Benchmark AHB2 amplifier and the M22 and some other amplifiers. One of his bugaboos was output noise, and noise that could...-
Channel: Class D Projects
by Chris D-
Channel: Club Halo/Parasound
by stevecussHi Folks,
I have an older RSP-980 surround processor driven by an RB980BX 2 channel amp. I run a pair of kit speakers and a powered sub and use it for music, tv, dvd etc. I'm very happy with the sound quality, but the processor is pro logic and not digital.
A local...-
Channel: Club Rotel
- Loading...
- No more items.
