What DVD player are you using with your system
  • bhuskins
    • 504
    I'll have to check the date of mine...I've tested the pluge and it passed. I don't use my 3910 that much though so it wouldn't be a huge issue for me. Have you read that certain firmware revisions have the issue or specific hardware? I find that some of us tech types are a little driven to always have the latest firmware for everything we own and it's not always the best solution. Many times a manufacturer throws out a fix that cause another unrelated problem. For example, it might make the DVD player's menu control slightly more responsive by a 10th of a second but it screws up the black level...no thanks. This is even worse in the software industry though.
    Yet another reason why I like Parasound's philosophy on software updates. A lot of the other guys out there that get updates every couple of weeks to fix bugs for their PrePro is no fun...especially for the dealer trying to support it.
    Brent Huskins
    Media Design
    HTGuide Sponsor
      Yeah, Brent, in the case of the 3910, that's what seems to have happened to me. My player didn't pass pluge. So I updated to the most recent -9 software, which didn't fix the pluge. But now my component outputs only pass a 4:3 signal, so the aspect ratio is screwed up.
      Looking all over the web, there's at least 15 instances I can see where people have verified that players made after August 2004 won't pass pluge. None of the firmware updates have fixed it, so it may be a hardware problem.
      Anyways, I'll take my 3910 woes over to the more appropriate sub-forum so we can keep this Parasound-focused.
      • rkburton
        • 21
        Any suggestions for the most simple (ie: cheape$t), reliable DVD player with optical out for the audio aspect and HDMI for the image aspect?
        I have a feeling that this will be the first item upgraded once all is set up.
        Parasound Halo C2
        Krell 250 a/3
        Krell 250a
        Krell 250a
        B&W 801 Matrix Series 2
        B&W HTM Matrix Center
        B&W 804 (side surrounds)
        B&W 805 (rear surrounds)
        Samsung 46" 750TOC
        • bhuskins
          • 504
          Welcome to the forum RK. :banana: ...that's from Chris D
          Probably the Bravo D2
          Brent Huskins
          Media Design
          HTGuide Sponsor
          • bhuskins
            • 504
            may not be the most reliable though...
            Brent Huskins
            Media Design
            HTGuide Sponsor
            • goldear
              • 111
              If you don't mind using a DVI adaptor, you might want to look at the low-end Denon 1910. It uses a slightly different Faroudja chipset than the higher-end models...but video supposedly looks the same. Secret's review has it passing all the important tests. I was actually looking at this for a stop-gap until the HD mess gets settled. Anyone have this?
              Chris B
              • bhuskins
                • 504
                The 1910's are great...I've sold a few and have had no issues. Definitely more reliable as well. The DVI adapter won't affect anything either.
                Brent Huskins
                Media Design
                HTGuide Sponsor
                • goldear
                  • 111
                  Thanks Brent. I didn't even know this little model existed until today when I saw one for sale at A-gon. Not a bad price, either
                  Chris B
                  • Kens1
                    • 191
                    I bought the Panasonic s97 dvd player a couple of months ago to tie me over until the HD thing happens. It is HDMI and plays dvd audio. I haven't compared it against other HDMI players but it was a big improvement over component video - brighter and crisper picture. It also uses the faroudja processer.
                    Oh yeah - it's very affordable. $330.00 Canadian which is about $200.00 American.
                      For the past 2 years, I've been hesitant to buy a DVD player with the very real possibility all along that a Halo DVD player was about to be released. Who knows.
                      • rkburton
                        • 21
                        I can't find the Panny S97S anywhere. It seems perfect, but it's out of stock in all the Googled locations.
                        Did it get replaced with a similar model number?
                        Parasound Halo C2
                        Krell 250 a/3
                        Krell 250a
                        Krell 250a
                        Samsung 46" 750TOC
                        • Duke
                          • 10
                          Just got my Esoteric DV50S as well. Sounds killer with my JM labs 927Be's. Much better than my Pioneer 47-avi
                          • mikepinkerton
                            • 86
                            I'm surprised nobody else is running a Panasonic RP91. One of the best progressive pictures around with prices under the stratosphere.
                            I can't upgrade because nothing comes close. Sigh.
                            -Mike
                            • ralniv
                              • Apr 2004
                              • 33
                              I had the same criteria as you and ended up buying the Oppo Digital OPDV971H and a Gefen DVI->HDMI converter. The picture quality is second to none unless you feel like spending 10x more. Read more about its performance at Secrets of Home Theater High Fidelity
                              Be prepared to run a calibration DVD because almost everyone needs to turn up the DVD player brightness setting to get the right SMPTE color bar appearance. My brightness is +8, but it will vary depending on your display (all the other settings were OK at defaults -- also typical for this player).
                              • LuckyLuke
                                • 30
                                I'm using a Marantz dv9500, my old Denon dv2800 wasn't up for the task
                                • misterdoggy
                                  • 1418
                                  Got a Pioneer DV 868 avi and am pretty happy with it.
                                  I was thinking about Krell Dvd
                                    • 27460
                                    Again guys, this topic of OFF topic. If it's not about Halo or Parasound, it don't belong in this Club-
                                      Review samsung DVD-HD1000
                                      by Lex
                                      Here's my "new" DVD player, the Samsung DVD-HD1000.
                                      This DVD player was really a surprise. I'd not heard of it, until accidentally finding one used on the net. Not knowing what it was, I went to the Samsung site to research it. What I saw was a beautiful player, that exuded...
                                      07 February 2004, 00:51 Saturday
                                    • csuzor
                                      Who is waiting for a Rotel SACD player?
                                      by csuzor
                                      Please vote if you would consider purchasing an SACD player from Rotel if it ever becomes available. Please choose if you
                                      1. prefer a pure audio SACD/DVD-A/CD
                                      2. prefer an audio+video universal DVD/SACD/DVD-A/CD
                                      3. prefer only a future HD-DVD/Blueray/SACD/etc player
                                      Audio only SACD/DVD-A/CD player
                                      11.76%
                                      14
                                      Universal DVD/SACD/DVD-A/CD player
                                      46.22%
                                      55
                                      wait for future HD-DVD/Blueray/SACD/etc player
                                      19.33%
                                      23
                                      have existing solution, not needed from Rotel
                                      10.92%
                                      13
                                      no interest in SACD at all
                                      11.76%
                                      14
                                      15 April 2005, 05:54 Friday
                                    • boe
                                      Good DVD player recommendations up to $500?
                                      by boe
                                      I'm looking for a good (but not outrageously good) dvd player to hold me over until the HD/Blue laser issue is resolved. I'm willing to pay up to $500. I have an older model that glitches even on straight out of the wrapper DVD's. My other DVD player doesn't have this issue....
                                      12 December 2004, 11:53 Sunday
                                      DVD's Coming Out This Tuesday - August 10th
                                      by David Meek
                                      Here's a list of most of the DVD's being released this coming Tuesday - August 10th. NOTE: Some of these may be re-releases.
                                      360 VM: The Standard
                                      Abbott & Costello Show, The: #11
                                      Abbott & Costello Show, The: #12
                                      Abbott & Costello Show, The: #13
                                      03 August 2004, 12:35 Tuesday
                                    • nicholtl
                                      What's the deal with CD player's used as transports?
                                      by nicholtl
                                      From my understanding, CD players/multichangers can be used 1 of 2 ways.
                                      1) As a transport.
                                      2) As a player utilizing it's own internal DAC's.
                                      As such, this basically means that by using digital interconnects (optical or coaxial) between the CD player...
                                      26 September 2004, 02:26 Sunday
