2 Subwoofers?
  • potatofarmer
    • Dec 2007
    2 Subwoofers?
    I'm building a home theater and I'm wondering if I should get another sub. My speakers are Paradigm studio 60 V3 and my sub is a Seismic 12. If I do get a second sub which one should I get? I know where there's a Servo 15a that I can get. Is it worth it? My room is 10 feet by 23 feet.
    Denis
  • Karma
    • 801
    HI Denis,
    Since you are not very specific about the important facts such as room size and preferred listening levels, etc, it is hard to advise you. And since you did not include this information I'll assume you are not very experienced with audio.
    I'll answer generally. In almost all cases two subs are better than one. Folks don't realize how hard low bass is to reproduce at realistic volume and low distortion. Two subs mean each has to work half as hard. That translates into less cone excursion which lowers distortion. The larger the room and/or the higher the voluume the more important having two subs is.
    Two subs also give you room placement options not available with one. This means that you can spread the standing waves to different positions and each will be half as intense. This is a very big advantage which translates into smoother bass.
    Sparky
    • potatofarmer
      • Dec 2007
      Thanks Sparky! My room is 10 feet by 23 feet. What kind of sub would you recommend for a second one?
      • Karma
        • 801
        HI Denis,
        I'm sorry but I don't get into "this one or that one" discussions. There are so many subs on the market, most of which I have never heard, that your guess is as good as mine.
        Do your research. There is wealth of information on the web. I will say that a very important factor is the ability to integrate the subs with the main speakers. This is tricky because it is an often unreported characteristic. I believe that buying subs is maybe the most difficult of audio purchases.
        Why? Because of the very limited opportunities to hear a variety of subs working in conjunction with your particular main speakers. This is the main reason I often suggest that the subs be made by the same company that made the main speakers. This may not give the ultimate bass performance but it does offer a degree of assurance that the subs and mains will work well together. You might want to consider calling the manufacturer of your main speakers and ask what they suggest.
        I'm sure others will chime in with their ideas.
        BTW, your room seems to be long and narrow in which smooth bass will probably will be difficult to achieve due to strong standing waves. Your room is a very good candidate for dual subs because of the placement options you will have. You may be better off buying dual subs that have a built-in equalizer and automatic room evaluation feature. Velodyne makes such a system.
        Good luck. If you get it right you will have great sound.
        Sparky
        • DarrenE
          Ridicubass Revisited
          by DarrenE
          Some of you may remember my project about a year and a half ago when I was “Attempting to achieve Ridicubass.” Although I am pretty happy with what I came up with after all the advice I received here I am starting to get the itch to buy some tools and cut some wood. I currently have two 4.6 cubic...
          21 March 2008, 10:53 Friday
        • swithey
          SWithey DIY Dual 15” Subs – Down to 15Hz
          by swithey
          Intro
          I’m a long time AVSer and have recently discovered HTGuide and the “Mission Possible DIY” Thread. I’m in the process of building out my HT and wanted to have some serious bass in the room. My small to medium sized room is 14.5’ wide x 19.5’ long x 8’ vaulted to 10’ ceilings...
          31 May 2006, 00:15 Wednesday
        • hawkson
          Best Speaker Design for Home Theater@2000$
          by hawkson
          I've been doing my research and need more direction.
          I have $2000USD for 5.2 setup, my room is 15x17 and I will sit 14 feet away, speaker 12 feet wide. Subs can be large, could go with 4 subs as well if money allows.
          I would like members advice on speaker design and...
          09 April 2011, 23:31 Saturday
        • George Bellefontaine
          calibrating two subs with Denon 3801
          by George Bellefontaine
          The 3801 only has one line level sub output. I have one sub at the front of the room ( approx 14 feet from my sweetspot) and the rear sub near the back wall and approx 6 feet from my sweetspot. I am using a splitter to run the back sub. I calibrated the front sub with the distance set at 14 feet. To...
          25 June 2001, 12:32 Monday
        • DavidY
          Improving Bass from Subs?
          by DavidY
          Just wondering if you can make a sub(s) more boomy so you can feel the bass more?
          IMO, most people have more problems with a sub that is too boomy. Not me! I have a pair of Mission 700AS subs that have good output. It can get very loud, but sometimes I wish that I could feel the bass...
          16 January 2001, 01:45 Tuesday
