Some of you may remember my project about a year and a half ago when I was “Attempting to achieve Ridicubass.” Although I am pretty happy with what I came up with after all the advice I received here I am starting to get the itch to buy some tools and cut some wood. I currently have two 4.6 cubic feet sealed subs with Soundsplinter RL-p15 d2 drivers powered by a Crown K1. The drivers are each wired to achieve a 4 Ohm load and each sub is driven by one channel (550 Watts) of the K1.
I am looking to build one ported box and compare it to one of my sealed subs and then if I prefer the ported to continue on with the process and build the second sub. I plan to put the new ported sub in place and then stack one of the sealed on top of it and switch back and forth between them to see what I think. Theoretically the only difference between the two subs should be the box in which the drivers are mounted. Everything else will be identical and since I plan to build a front firing sub the drivers should be within inches of each other so there should be very little difference in room interaction. The room is decently treated with acoustic panels and bass traps.
Here are the basic design criteria. These are based on the “ideal” design on the Soundsplinter website.
10 net cubic feet after subtracting port and driver volume.
14.5 Hz tune.
I want both the driver and the port to be front facing. I really like the look of the AV123 MFW-15 but don’t know how feasible the slot port would be with that low of a tune. I think a 6” round port at about 32” long would put me in the right neighborhood for a round port.
Any suggestions would be welcome. This should be a very cheap project since I should only have to buy wood and something for the port. I’m not counting the price of the saw/saws I will have to buy since I will use them for some other things I need to do around the house. Everything else can be reused or I have leftovers from building the first subs.
I also would like suggestions as to which type of saw I should purchase to make the cuts. I only needed a router for the sonosub since I had Lowes make the rough cuts for me to work with. Would a table saw be better or do I only need a circular saw with some sort of straight edge to make the cuts. I’m a serious amateur with the wood working so don’t know which way to go with this.
Any and all suggestions will be appreciated.
14.5 Hz tune.
