Intro
I’m a long time AVSer and have recently discovered HTGuide and the “Mission Possible DIY” Thread. I’m in the process of building out my HT and wanted to have some serious bass in the room. My small to medium sized room is 14.5’ wide x 19.5’ long x 8’ vaulted to 10’ ceilings (about 2500cu/ft). I’m looking do dual 15” subs with one in the front (behind a 2’ deep false wall) and one in the back left corner of the room. I’m also interested in having subs that can dig down deep – somewhere around 15Hz if possible (to coin the term "Ridicubass" DarrenE created)
Equipment
Drivers: SoundSplinter RL-p 15
Amp Opt 1: O Audio Plate Amp/per sub (500WPC) <OR>
Amp Opt 2: Behringer EP1500 (700WPCx2)
EQ: Behringer DSP1124P
Design
I’ve considered both the standard box shaped and Sonotube designed subs. Knowing that the sonotube is easier to build (and a lot lighter), I have still decided to go with a standard box design. However, I am interested in a ported version to get me down around 15Hz (as I do not think a sealed model in the size I’m looking to do will get that low). This is the design I am looking to create. It’s not too hard to build and I plan to veneer it after it is completed to match the columns in my HT.
Size
I would like to keep depth and width to no more than 22” since I plan to put one behind my 2’ deep false front wall. This will give me a little more placement flexibility in that area. If this is not possible, depth can be more but width will need to remain the same. I’m okay for height to about 42”-48”. Anything larger may be hard to carry upstairs into the room and WAF comes into play too. BTW - The other one will be placed in the back left rear corner of the room (and will be visible).
Possible Issues
Since I will have dual subs, I’ve been told that phase control is important. This is one reason I was looking at the O Audio plate amps. They have a nice phase control setup. However, my concern is the distance from my Pre/Pro to the sub is about 55 feet (over RG6) for line-level audio (needed for the O Audio plate amp). I could put both plate amps in my equipment closet and run speaker level to the subs. If I go with the Behringer EP1500, the distance is not as important. I also ran a pair of 12/2 speaker wire to the same location for this very setup. I like that the Ep1500 would save me some $$ but it does not offer phase control. I think if I step up to a Crown amp, I get that feature but for more $$ (I cannot remember the model).
Help Needed - Please
Now with all that said, this will be my 1st DIY sub. I have been reading/following at least a dozen DIY Sub threads over the past 3-4 months. I feel comfortable with the build but need some assistance with box size, port size and port length. Because of my limited depth, we may need bend the port "internally" toward the top to get the length we need. I was hoping you guys could guide me along this journey and help me achieve the performance I’m looking for in these subs.
Equipment
Design
Size
Possible Issues
