claritycap esa or jantzen standard-z cap ?
  • Audiophile100%
    • 128
    i have a doubt on the cap choice.
    does someone has tried botrh of them ?
    thank you
  • carlthess40
    • Jun 2019
    • 9
    Good question, also what one is best for crossovers and what one is good in preamps
      I've always been a bug fan of the ESA.
      Sent from my SM-G975U using Tapatalk
      • Audiophile100%
        • 128
        do you tried jantzen standard z cap?
        how sound the esa?
          how sound the esa?
          Was not impressed by their Standard caps.
          As for the ESA, slightly warm to neutral.
          • Audiophile100%
            • 128
            so compared to ESA?
              • 1038
              The new(er) CSA series is remarkably compact if that means anything. I had a photo around here, I think, showing the difference between it and a Superior Z. If board space is at a premium, then the CSAs are worth considering.
              • Audiophile100%
                • 128
                thank you, but CSA is too much for me.
                in this project the battle is: jantzen standard-z cap vs clarotycap ESA
                do you compared CSA vs ESA ?
                  • 1038
                  I have used the PX series a decade ago, and larger caps in that series were ... large (100uF was basically a soda can). My most-recently completed Helios build used Superior-Z. I had built the same crossovers previously with CSAs, which is why the form factor was memorable, but I didn't like how much carbon I had in the solder joints (crispy!). That was why I went with the Superior Z caps. As a result, the PX caps were competent, but unexciting. The Superior Z caps were about peace of mind. I'll de-solder the CSAs sometime soon, and see if I can re-use them on a project. I still have a bunch of the PX caps in my parts box as well.
                  If budget is a true concern, I'd recommend Solen Fast Caps. I've used them before, as well. They won't get anyone excited, but they are still workhorses. I use them as a go-to for parallel caps. I built the crossover for a pair of gift bookshelf speakers entirely out of them and the Dayton equivalents. A standard civilian won't know the difference.
                  • Audiophile100%
                    • 128
                    excuse but i don't understand what you write.
                    superior-z vs CSA ?
                      • 1038
                      superior-z vs CSA ?
                      For a given rating, the Superior-Z caps are noticeably larger. See the size difference here:
