Cabinet Tuning
  • scary
    • Jul 2016
    • 13
    Cabinet Tuning
    What is the procedure for calculating port dimensions to tune a cabinet for a certain frequency? I am building a pair of Cinema 893 towers that were designed for a sealed enclosure. I understand that a 70 liter box tuned to 35Hz works very well, so that got me interested in the process. Is there is a simple formula, or do I need cabinet design software?
    Scary
  • DigitalMaven
    • Feb 2017
    • 36
    Scary
    There are online port calculators...here's one of them
      Here is the page for Unibox software. You use it with Excel. Works very well and straight forward to me.
      Jeff Bagby also has an excellent program that runs inside excel to model woofers. It will also do boundry loading and such:
      Finally, a LOT of people like to use WinISD. I don't get WinISD. You have to enter the driver parameters in a specific order and have accurate/correct driver parameters or it just doesn't work. Other things too. I like the other two programs better. But, a lot of people use WinISD. If you don't have Excel with the math solver add on, this might be the way to go.
      Give those a try. If you post screen shots of your input and such, we can help walk you through it.
      • Audion
        • Mar 2017
        • 5
        Yes, I think that WinISD is very popular because the results that you get aren't overly complex and are rather easy to understand.
        It doesn't require you to put in as many parameters as some other programs, so some people like that convenience.
        However, the other commenter is right in that you have to get all of the parameters input properly, or you have to start over.
        Also, you only get four graphs of results, and those don't tell you some of what you need to know.
        One of the more important things that you'll need to know when designing an enclosure is cone excursion (how far the cone can move without distortion or even bottoming out).
        Many small woofers and midbasses will play low frequencies according to the gain/SPL graph.
        But, you may find that the speaker cannot play very loudly at all because you'll run out of cone excursion even at low SPL levels in some cases (because of the demands placed on it to play at very low frequencies).
        So, it's nice to have a program that lets you input a power level, check the SPL level and also verify what the cone excursion is at those levels.
        When using these programs, be sure to use the correct units when entering data, too.
        • evilskillit
          Question Regarding WINISD Pro
          by evilskillit
          I notice that when I put speakers into WINISD, in this case subwoofers, that the auto calculated values are sometimes pretty different than what the manufacturers list. I was wondering which generally gives a more accurate picture of how a driver will work. I know that WINISD calculates the values according...
          07 February 2009, 15:19 Saturday
        • Txgrizzly
          Loading tweeter stats into WinISD
          by Txgrizzly
          All,
          i just downloaded WinISD from the web and i was able to load my Dayton RS150S-8 perameters no problem but the program wont allow me to load the Dayton RS28A-4 1-1/8" Aluminum Dome Tweeter due to missing parameters like QTS, VAS, LE ETC... is there a place where i can get those #'s for...
          19 June 2009, 21:42 Friday
        • Finleyville
          Unibox vs. WinISD for sub box calculations?
          by Finleyville
          Anyway...
          I have an old Adire Koda 10 sub not being used and thought I would try my hand at my first sub.
          Plugging in all the driver's parameters in both programs gives me some serious deviations between them.
          Modeling for a total Qts=0.707 the suggested...
          29 January 2009, 08:15 Thursday
        • Jerm357
          Series resistance for a RL-P 15 D2? And check the parameters
          by Jerm357
          In Winisd what should I put as the Series resistance for a RL-P15 d2 wired with each channel of an EP1500 to each 2 ohm VC? And do thses these parameters look right?.......I entered them in the order as the help file says to auto calculate the unknown and this is what it came up with.
          19 July 2006, 14:28 Wednesday
        • Jordan
          Dayton DA-175 project cabinet
          by Jordan
          I just finally made my mind on what project to build. I chose those DA-175 because of their good bass.
          I just posted a thread on parts-express.com board and go no answer to my cabinet question...
          I have the driver selection, and the crossover schematics, (thanks to M. Jakubin)....
          29 June 2006, 08:01 Thursday
