Anyway...
I have an old Adire Koda 10 sub not being used and thought I would try my hand at my first sub.
Plugging in all the driver's parameters in both programs gives me some serious deviations between them.
Modeling for a total Qts=0.707 the suggested volume from Unibox is 22.6 liters while WinISD figures it to be 37.3 liters. I think that is quite the difference.
I double checked each program's driver stats to make sure they are both the same.
Which should I use?
Adire Koda 10 MkI
Re= 2.8 ohms
Le= 1.3 mH
Fs= 28 Hz
Qms= 3.50
Qes= 0.42
Qts= 0.38
Vas= 85L
Sd= 344 cm^2
Xmax= 18 mm
Pmax= 300 W
Which should I use?
Adire Koda 10 MkI
Re= 2.8 ohms
Le= 1.3 mH
Fs= 28 Hz
Qms= 3.50
Qes= 0.42
Qts= 0.38
Vas= 85L
Sd= 344 cm^2
Xmax= 18 mm
Pmax= 300 W
