DUAL TV TUNERS????? HELP!
  • jaruiz
    • Sep 2003
    I was wondering if it would be possible to use dual TV tuners to record two seperate shows at the same time. I saw a commercial for the local Paragoncable company advertising a DVR that could do just that. It got me thinking and I came up with the idea that it would require two seperate tuners. I figure it'll take a fairly powerful computer, so the minimum requirements would definately be raised but I don't see why it couldn't be possible (unless due to software constraints, the computer would have a hard time addressing both computers. ) I figure using dual harddrives would solve any problem there. ANy comments?
  • Bing Fung
    • 6523
    If I understand correctly you want 2 TV tuner cards in one PC? That is an interesting setup. About the only issues I could see is Windows may not be able to drive both tuner cards at the same time. although I'm not positive on that.
    I'm sure the CPU requirements could be large as well, however I think the first issue is the deciding factor.
    Bing
    Bing
      power requirements?
      by Andrew Pratt
      I am in the process of installing a dedicated HT in my basement and am nearly ready to install the power for the gear rack. I plan on running some lines directly from the breaker box to the gear rack so the gear isn't sharing power with anything else in the house. The question I have is what do I really...
      18 April 2002, 10:23 Thursday
    • uncle_git
      802's and power requirements
      by uncle_git
      How much power do the 802's really require to drive them hard ?
      I'm seeing quotes about 500W for the 801's on various forums - but no real feedback on the 802's - I was thinking of driving them with an amp that put out 200W per channel - is this going to be enough or should I go looking...
      14 October 2004, 00:17 Thursday
      Dual Display Wierdness
      by David Meek
      My PC is misbehaving, and I could sure use some help.
      I'm running a:
      Dell Precision PWS 470
      Xeon 3.2 GHz CPU
      ATI FireGL V3100 graphics cards (both monitors)
      Dell 19" flatscreen monitor - model 1905FP
      XP Pro SP 2
      The...
      12 September 2005, 10:48 Monday
    • LJDUTOIT
      Dual subwoofer configuration
      by LJDUTOIT
      Hi all, first post on this forum so please bear with ignorance!
      I recently added a large windowless HT room (7x6x3m) to my house, in brick and mortar (with a solid 350mm thick cement slab as roof). I also have a rather old set of AV components, but this is not the reason for the post....
      30 December 2007, 06:48 Sunday
      tuners
      by Andrew Pratt
      The topic of tuners came up over in the outlaw club regarding the new pre amp and I've never used the one in my Denon recevier. So in your oppinion is the inclusion of a tuner a must have or a waste of resources? For me I'd sooner not have it since the only time I listen to the radio is in the car as...
      30 May 2001, 10:35 Wednesday
