IR Repeater Problem
  • bmowis
    • Oct 2006
    • 45
    IR Repeater Problem
    Last night I was trying to set up a new IR relay system I recently purchased from Parts Express consisting of a Buffalo IR-100 receiver and the IR-250 repeater. Also picked up a bunch of IR-E1 flashers.
    Got it all set up and started playing with it. When I press buttons on my remote, I see a little green LED on the repeater start to flash. Also, I see another green LED on the receiver flash as well. Finally, I also see the red light on the IR flasher blink, too.
    However, when I hold the IR flasher up to the IR lens of any of my devices and attempt to use the remote, nothing happens...except when I use my lighting control remote, which I can get to work *some* of the time.
    Any ideas as to what is going on, here? On the surface, everything appears to be functioning normally, but flashers don't seem to be making my gear do anything.
    I'm trying to control:
    Marantz AV8003 Pre-pro
    Sony BDP-S350 Blu-ray Player
    Toshiba A2 HD-DVD Player
    Oppo 980 Universal
    Lexicon Remote Controlled Dimmer (for lighting), which works when I hold the remote about 6 inches away from the IR Repeater and start pressing buttons.
    Also, I'm using Cat5-e cable to connect the Repeater to the Receiver. Both the repeater and the receiver have three recepticles for 3 wires labelled V+, Sig, and Ground. I'm using 2 twisted pairs to make the connection - one pair is used to connect V+ and Sig from the repeater to V+ and Sig on the receiver, and the other twisted pair (both wires) is used for ground.
    I've double checked my wiring, and as far as my limited knowledge can assure me, everything is connected correctly and securely.
    I'd sure be grateful for any help you could give me. Thanks in advance!
    Brad
  • bmowis
    • Oct 2006
    • 45
    Nobody? ...Okay, anybody want to buy a Buffalo IR Receiver/Repeater set with flashers? Works great!
    • DrJazz
      Odd RSP-976 remote issues...and a fix!
      by DrJazz
      I just wanted to share an odd experience I've been having with my trusty old RSP-976 surround sound processor. For quite some time now (well over a year, maybe more) I've been having one helluva time with the remote control. Specifically, the 976 would only respond intermittently to volume up and down...
      10 April 2005, 08:30 Sunday
    • Stevebez
      Rotel 1050 remote... an alternative.
      by Stevebez
      Sorry to place in this forum but think you guys should know my great experience here ... given the 1050's really rubbish build quality... (come on guys ... whats going on here ?)
      Initially I was after a Pronto Pro etc etc ... while fanatastic it also had a very fantastic price... and...
      06 March 2005, 03:58 Sunday
    • efarstad
      1066, Remote, & IR Repeaters
      by efarstad
      Ok...some of you may have watched my journey as I built my HT. Well, I just finished connecting my IR-Repeater system which consists of the following:
      Stealth IR Sensor
      of which is connected to this:
      Connecting Block
      of which...
      15 January 2003, 14:38 Wednesday
    • clearwaterms
      which IR repeater
      by clearwaterms
      okay,
      can somebody please educate me. I need an IR repeater setup. I have three devices, DVD player / HT reciever / Comcast cable box. They will be driven off of a harmony, but I still need the repeater. anybody have any suggestions?
      08 January 2007, 10:12 Monday
    • gruss
      IR repeater for zone 2 on RSX 1067
      by gruss
      Just wondering if anyone has had any luck with any products to control zone 2 with the 1067. Got it all hooked up and it works just fine, but would be nice to be able to adjust the volume or change sources without opening the door. Looking for a fairly cheap solution and have no experiance whatsoever...
      30 September 2007, 09:23 Sunday
