Rotel 1080 amp has 12v trigger, Yamaha RX-V1400 doesn't... Ideas?
  • azsyno
    • 50
    Want to utilize my Harmony 880 remote to turn on the Rotel Amp when turning on/off all functions. Problem is that my Yammy Rx-V1400 doesn't have the 12v trigger function. Can I purchase a device that will alleviate this issue? don't really want to add a Rotel (or other) reciever just to get this function...
    Thoughts?
    Thank you!
  • Kevin D
    • 4601
    12v power supply plugged into the back of the 1400's switched outlets.
    Kevin D.
    • azsyno
      • 50
      Kevin,
      I found a thread that helped after I saw your post. I'm seemingly all set... Need to find out from someone though if the blue light on the Rotel 1080 should go out when all is turned off. The Rotel manual doesn't mention this, but does say the Power button always needs to be turned on. I checked the trigger and it's operational, but now am wondering why that Blue light on the Rotel would always stay on. Doesn't seem right to me... Who am I to say though? I coudn't even figure out a good way to create a trigger until today and now it seems so basic :-/
      Ideas on that blue light?
      • Kevin D
        • 4601
        As per the thread in Rotel Club, it should stay on all the time. Glad you got it worked out!
        Kevin D.
