Front Projection
  • anilv555
    • Oct 2004
    • 8
    Front Projection
    I am very interest in PJ but I am new to it so what should i look for in a PJ my budget is around $1100 to $1200
    I saw the Ez Pro 732 for $800 and i wanted to know if it is a good buy and whether i should buy it i will be mainly watches movies, hdtv and occaisanol sports and
    thanks in advance
  • anilv555
    • Oct 2004
    • 8
    the Ez Pro 732's Specs
    Display Technology: Single 0.55-inch Double Data Rate DLPÔ technology from Texas Instruments
    Resolution: SVGA (800 x 600) native
    SXGA+ (1,400 x 1,050) compressed
    Brightness (typical): 1,400 lumens
    Contrast Ratio
    (full on/full off): 2000:1
    Weight: 4.9 pounds (2.2 kg)
    Dimensions
    (W x H x D): 10.7 x 3.4 x 8.3 inches
    (272 x 86 x 211 mm)
    Noise Level (typical): 32 dB
    Lamp Type and Life: 200-watt SHP lamp
    2,000 hour
    3,000 hour (Eco Mode)
    Aspect Ratio: 4:3 native, 5:4 and 16:9 compatible
    Input Connections: PC/Video:
    15 pin D-sub input (RGBHV/YPbPr input)
    15 pin D-Sub connector to take a SCART RGB signal (sync on the composite line), via an adaptor.
    Video:
    One mini DIN for S-video connector
    One composite RCA type connector
    USB Mouse control
    One Audio input for every input- (3.5mm Mini Jacks stereo)
    Output Connections: 15pin monitor output (passive)
    Computer Compatibility: IBM PC and compatibles, Apple Macintosh, iMac, NEC PC98 series, Fujitsu FM Towns, and VESA standards SXGA, XGA, SVGA, and VGA (resizing)
    Video Compatibility: NTSC: M(3.58MHz),4.43MHz,480i
    PAL: B, D, G, H, I, M, N
    SECAM: B, D, G, K, K1, L
    HDTV: 480p, 576p, 720p, 1080i
    Throw Ratio: 1.75 - 2.12:1 distance/width
    Keystone Correction: ± 16 degrees
    Remote Control: Wireless remote with optional mouse control
    Projection Screen Size (diagonal): 32.5 to 337.5 inches
    (0.84 to 8.58 meter)
    Projection Distance: 4.6 feet to 39.4 feet (1.4 to 12 meter)
    Projection Lens: F/2.4-2.7; f 19.7 -23.6: 1.2x manual zoom lens
    Projection Methods: Front, rear, ceiling, rear ceiling
    Data Loop Through: Passive monitor loop through
    Horizontal Scan Rate: 31.5 to 80 kHz
    Vertical Scan Rate: 43 to 85 Hz
    Operating Temperature: 41-95°F (5-35°C)
    Power Supply: Universal AC90-264V / 50-60Hz with PFC input
    Power Consumption: 280 watts maximum
    Security: One Kensington key lock port
    Tilt Angle: 7 degrees with elevator mechanism
    IR Receivers: Front and back
    Uniformity: 85%
    Displayable Colors: 16.7 million colors, 256 shades of gray
    Standard Accessories: AC power cord (three prong) 1.8m
    Composite video cable 1.8m
    15pin monitor cable 1.8m
    Remote control
    Battery for remote
    Lens cap (hanging)
    Users guide
    Quick start guide
    Warranty card
    SCART to 15 pin D-sub adapter (EMEA only)
    Carry case
    Optional Accessories: 15-pin to 3 RCA component/HDTV hookup
    S-video cable 1.8m
    Warranty: Two year limited parts and labor, 90-days on lamps
    • George Bellefontaine
      • Jan 2001
      • 7637
      Don't know anything about that model. It isn't one they promote for home theater as far as i know so I can't really say how good it would be. But it may be an okay starter PJ for $800. Is that new or used ? I ask because you can get widescreen lcd PJs for around $1200 USD brand new. And for around $1400 you can get the Infocus dlp widescreen 854 x 468 PJ. Some members here have this projector and love it. Check out the threads below.
      My Homepage!
      • anilv555
        • Oct 2004
        • 8
        thanks george but this is a new one and when i checked out some other websites this is promoted for ht use and why is the Infocus you mentioned better than the 732?
        thanks
        • anilv555
          • Oct 2004
          • 8
          Yeah I just checked with my local best buy and they have it for $899 brand new so I need suggesstions my budget for the actual PJ is about $1100 cuz I am only 16 and we just bought a new house and I have been checking out the forum for a while now and my dad was looking for a "Big Tv" so I suggested a PJ and so me and my 18 brother have the responsibitly. we have a unfinished part of a basment so we finsih into a home theater. so thats why my budget is so low and I am open to any other suggestions of PJ's
          thanks
          • anilv555
            • Oct 2004
            • 8
            Also I would like to add that projectorcentral.com has a good rating on it and good reviews : http://www.projectorcentral.com/part...pinion_id=4299 but i dont know if thats a realiable website
              • Jan 2001
              • 7637
              The Infocus model 4805 I referred to has widescreen dmd panels or 1:78:1. With the Optoma 800 x 600 (4:3) dmd panels you will get light spill above and below widescreen material such as dvds and widescreen hdtv programs.
              My Homepage!
              • anilv555
                • Oct 2004
                • 8
                thanks
                Ok so how much is the 4805?
                  • Jan 2001
                  • 7637
                  I mentioned it in a post above. It is around $1400 USD msrp.
                  My Homepage!
