Proxima 5800 sound input problem
  • sdunham
    I am trying to (successfully) connect an IBM i series laptop to a proxima 5800 projector. I can bring up the picture, but not the sound.
    To transfer sound, I am using a Y-Adapter Audio Cable that I purchased at Radio Shack.
    I used headphones to make certain that the laptop was producing sound. It is, so that's not the problem.
    Any ideas?
    sdunham
    • 16209
    Are you trying to connect the sound output from the laptop to the projector? Are you sure the projector has speakers built in? I'm not familiar with that Proxima model. You might try using another signal source, to test that it isn't a problem with your cables. Also, be sure you have the right type of audio cable- stereo, judging from the spec sheet on the 5800. A mono cable may short the output.
    • sdunham
      Proxima 5800 sound problems
      Thanks, Jon --
      I'll check it out. If this is not the answer, I'll be back.
      Sdunham
      • mhutchins
        Proxima 5800 Video Drops Out
        by mhutchins
        I have an old Proxima 5800 that has been great for the occasional presentation around town. I've decided to use it with my playstation 2 and I'm having mixed results. I've connected the Playstation to a VCR and connect to the 5800 via a Video component cable (the yellow one). At first the games run...
        02 August 2005, 15:20 Tuesday
      • talons24
        Proxima 5800 Purple spots?
        by talons24
        I have a Proxima 5800 projector with purple spots on the screen. I bought an extra bulb as I thought the bulb had burn spots on it that were transfering to the screen. That didnt fix it. Three questions (1) Does anyone know if it can be fixed? (2) if it can be fixed can I do it and if I can can someone...
        21 April 2006, 18:36 Friday
      • Bam!
        PROXIMA anyone heard of this?
        by Bam!
        Hey guys!
        My friend is driving me nuts with all these FP questions...anyway he wants to know about a Proxima desktop 5800...
        Do you know about this cause he can pick it up in a pawn shop for 650.00$ Canadian....
        Thanks a lot!
        22 March 2004, 09:41 Monday
      • Toulouse
        Color in Proxima 9250+ - Help Please
        by Toulouse
        Proxima 9250+ has started having extreme color distortion when projecting RGB signal. . . signal is split and looks fine on monitor, but projector color balance is way off. . . attempts to change using projector menu is not successful. . . .any ideas. . . thanks in advance.
        KJ
        20 October 2004, 13:05 Wednesday
      • bigbop
        Proxima DP5900 leaking liquid from optics?
        by bigbop
        I was just given a Proxima DP5900 because the screen is a fuzzy blue and has what looks like a bite taken out of the top of the image (projector was mounted on a ceiling). I took the top cover off and found a sticky liquid inside had leaked out of part of the optics between the LCDs and the front lens...
        05 February 2006, 22:31 Sunday
