Which would you have:
VPLVW100
Optical Specs
Resolution: 1920 x 1080 native pixel resolution
Panel type: 0.61" SXRD panels x 3 (each having 2,073,600 pixels)
Pixel response time: 5ms
Pixel size: 7 microns high with 0.35 micron separating each pixel
Contrast ratio: 3,000:1 to 15,000:1
Projection system: 3x SXRD panels with 1 lens
Lens type: High Resolution All Range Crisp Focus (ARC-F)
Lens zoom range: 1.8 x powered zoom
Lens shift: 0.65 x Screen Height (Up or Down) 0.067 x Screen Width (L or R) from dead centre
Screen coverage: 40" - 300" (widescreen viewable area measured diagonally)
Lamp type: Xenon
Lamp wattage: 400W Xenon Lamp (LMPH400)
Expected Lamp Llife: 2500 Hrs
Fan noise level: 22 dB due to silicon nipple insulating joints holding fan, optimized shape of fan blades & a non-contact fan shaft mechanism
Signals Accepted
Video: DTV - 480i,480p,576i,575p,720p,1080i, 1080p (HDMI & DVI-D only), 15khz RGB/Component, Progressive component,Y/C, Composite
Computer: Up to 1920 x 1080 @ fV 60Hz, fH: 19 to 72 kHz, fV: 48 to 92 Hz
Colour systems supported: PAL,PAL-M, PAL-N, NTSC, NTSC4.43 & SECAM
Connections
HDMI input: x 1
DVI-D input: x 1
15-pin D-sub input: x 1
Component video input: x 1
S-video input: x 1
Composite video input: x 1
Ethernet RJ-45 10/100 input: x 1
RS232C D-sub 9 pin input: x 1
12V minijack trigger input: x 1
Throw Distances
(16:9) 40" : 1.2 - 2.1 m
(16:9) 60" : 1.8 - 3.2 m
(16:9) 80" : 2.5 - 4.2 m
(16:9) 100": 3.1 - 5.3 m
(16:9) 120": 3.7 - 6.4 m
(16:9) 150": 4.7 - 8.0 m
(16:9) 180": 5.6 - 9.6 m
(16:9) 200": 6.2 - 10.7 m
(16:9) 250": 7.8 - 13.4 m
(16:9) 300" : 9.4 - 16.1 m
General
Cabinet colour: White
Power consumption: 610W (Max) 10W (Standby)
Power requirements: AC 100 to 240V, 50/60 Hz
Dimensions: 496(W) x 574(H) x 175(D) mm
Weight: 19 Kgs (Approx)
or
KDL46X2000
Integrated High Definition Digital Tuner: Yes
Native Display Resolution: 1920 x 1080
BRAVIA Engine: EX
Viewing Angle: 178
Screen Format: Wide Zoom / Normal / Full / Zoom
Picture Mode: Vivid / Standard / Custom
Multi Picture: Yes
Noise Reduction: Yes
Brightness: 450cd/m2
Contrast: 1500:1 (On-screen), 7000:1 (Dynamic)
Response Time: 8ms
Sound
Audio Output: Yes
Sound Mode: Dynamic / Standard / Custom
Surround Mode: Dolby Virtual / Simulated Stereo / Off
BBE Digital: Yes
Terminals
HDMI Input: x2
Component In: x3
S-Video in: x2
Composite in: x3
Headphone Out: x1
HD15 / PC Audio Input: x1
Other Features
Power Saving Mode: Yes
Clock: Yes
On / Sleep Timer: Yes
Teletext: Yes
Light Sensor: Yes
Cinema Drive: Yes
OSD Language: English
Swivel: -
General
Power Requirement: 221 - 240 V 50/60 Hz
Power Consumption: 260W
Dimensions with stand (WxHxD mm): 1262 × 795 × 322
Dimensions without stand (WxHxD mm): 1262 × 734 × 121
Weight with stand (Kg) : 41
Weight without Stand (Kg): 36
If they where both the same price, and your HT room would support either.
VPLVW100
Optical Specs
Lamp type: Xenon
Signals Accepted
Connections
HDMI input: x 1
DVI-D input: x 1
S-video input: x 1
Throw Distances
General
or
KDL46X2000
BRAVIA Engine: EX
Viewing Angle: 178
Multi Picture: Yes
Response Time: 8ms
Sound
Audio Output: Yes
BBE Digital: Yes
Terminals
HDMI Input: x2
Component In: x3
S-Video in: x2
Composite in: x3
Headphone Out: x1
Other Features
Clock: Yes
Teletext: Yes
Light Sensor: Yes
Cinema Drive: Yes
Swivel: -
General
