Mirror EQ with VituixCAD
  • How To: Mirror EQ with VituixCAD
    With VituixCAD, we have the ability to provide a mirror EQ function, that can then be passed to APO EQ for active processing. This allows for a speaker's frequency response to be fully compensated for without requiring many bands of parametric EQ.
    ​VituixCAD Process
    Connect each driver and EQ blocks in the crossover section as shown. Ensure that the active peak/notch filters are “shorted” so that only the G(f) block is directly connected to the driver. Three PEQ blocks are show, you may include as many or as few as are needed.
    1. Load all driver responses in the drivers tab. Set smoothing for each driver at 1/12 oct to avoid unnecessarily detailed correction with FIR EQ.
    2. Connect each driver and EQ blocks in the crossover section as shown. Ensure that the active peak/notch filters are “shorted” so that only the G(f) block is directly connected to the driver. Three PEQ blocks are show, you may include as many or as few as are needed.
      Click image for larger version  Name:	dataurl055978.png Views:	0 Size:	17.8 KB ID:	927400
    3. ​Using the Optimizer window, select “axial response of driver”, then select the driver to be optimized in the drop down menu top the right. Define the target slope and high pass or low pass function as desired.
      Some care of the target slope is necessary to avoid extreme gain requirement for the mirror filter. For example, a flat to 20kHz response for a 12” woofer will result in extreme gain requirement at high frequency. As well, target response at low frequency should be similar to driver low end roll-off as any EQ in the sub range requires many taps for a DSP system.
      In order to prevent over-correction of the EQ or compensation for measurement noise floor, selecting the frequency range in the optimizer will limit the range that is to have EQ applied. Uncheck “Free LF” and “Free HF” to have the EQ follow the slope of the response beyond the EQ limits. Checking either of these boxes will apply a flat 0dB/oct slope beyond the frequency limits. ​
    4. Select the G(f) block for the driver, then press the “->TF” button to export the target transfer function. This will save the target response file and load it to the G(f) block. If the G(f) block hasn’t been selected, you must load the file manually by selecting the block and using the open button at the bottom of the main window.
      Click image for larger version  Name:	dataurl140551.png Views:	0 Size:	56.4 KB ID:	927401
      Optimizer Window
      Click image for larger version  Name:	dataurl159888.png Views:	0 Size:	54.6 KB ID:	927402
      ​High Pass Target​
      Click image for larger version  Name:	dataurl219846.png Views:	0 Size:	56.7 KB ID:	927403
      ​Low Pass Target
    5. ​Repeat Steps 3 and 4 for each driver in the system.
    6. Enable active peak/notch filters and optimize the system for listening window, in-room response, power response as needed.
      Click image for larger version  Name:	dataurl316845.png Views:	0 Size:	22.9 KB ID:	927404
      ​Filter Schematic
    Click image for larger version  Name:	dataurl357982.png Views:	0 Size:	319.9 KB ID:	927405
    ​Complete system with optimized responses
    Complete IR export and utilize within APO EQ for active processing. See my instruction “filter simulation with EQ APO and VituixCAD” for details on this process.
      Posting comments is disabled.
    Latest Articles
    • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
      by theSven
      By Jon Hancock
    • Cult of the Infinitely Baffled
      by theSven
      IB- F.A.Q.
      1)What's an IB?
      For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
      2)Which space is best?
      Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
      15 December 2024, 12:17 Sunday
    • How to: Measure with REW for Room EQ
      by Reet
      REW is a powerful tool, as is EQ, but getting it right can be challenging. The first step to achieving a good EQ profile for your space is to take in-room measurements. This document will detail an easy method to achieve quick and reliable results.
      For room EQ, a single measurement at your listening location will not produce a good depiction of the overall room response. An average of many measurements around the listening area should be completed to create a room response for equalization...
      12 April 2023, 10:42 Wednesday
    • Minimum Phase and Accurate Crossover Simulation
      by Reet
      Minimum phase for a speaker can be described of the phase of the frequency response of the speaker at it’s acoustic centre, or the phase without any excess phase or “time of flight” included. It can be calculated from the speaker’s frequency response using Hilbert-bode transform, or HBT. When comparing multiple minimum phase responses, we can say that the responses occur at the same point in space, ie. there is no physical distance between them. When measuring speakers and processing the...
      26 December 2022, 14:27 Monday
    • How To: VituixCAD Extended Impedance Model For Any Driver
      by Reet
    • How To: Measuring impedance and T/S with ARTA/LIMP
      by Reet
      With a simple jig, loudspeaker impedance and T/S parameters can be easily measured with LIMP. The same jig may also be used to measure component value for resistors, capacitors, and inductors, as well as measure transfer functions of passive and active filters.
      The setup is quite simple, the following diagram is taken from the LIMP manual:
      https://artalabs.hr/download/LIMP-user-manual.pdf
      Measurement Jig ​
      This instruction is following what is in...
      26 December 2022, 14:02 Monday
