Filter Simulation with VituixCAD and EQ APO
  • How To: Filter Simulation with VituixCAD and EQ APO
    With meticulous passive filter design, it may be beneficial to hear the result before spending money on crossover parts and putting in the time to assemble the crossover. Fortunately, with VituixCAD and EQ APO and filter can be simulated digitally. This process can simulate multiple drivers simultaneously, one driver for each output on a soundcard, for example a 7.1 soundcard could simulate a stereo 3 way system utilizing 6 channels.
    Note that an emulated passive filter will reproduce the filter transfer function as a digital filter entered into a DSP, it does not provide exactly the same result as a real passive filter due to different source impedance and component features. Passive filter interaction with the driver non-linearities and back EMF for example will not be present in a digital simulation.
    VituixCAD Process
    1. Once you have a complete design ready for simulation in VituixCAD, simply select “Impulse Response” under the view menu.
    2. Select the sample rate that your soundcard is set to for playback.
    3. FFT Length can be set to the maximum value of 262144, any value 65536 or higher is more than enough to cover the low frequency response.
    4. Taps can be set quite high as well, 8192 taps should be more than enough to cover most uses.
    5. Select IR Window as desired, since we are exporting a full frequency response using a large FFT length, the exported result is essentially “un-gated” so the selection here is not extremely important, however I have used “cosine”.
    6. Uncheck “Center IR”
    7. Set Pre-delay at 1.0ms
    8. Under Signals to export, select the “D” button, which will fill in all drivers in the project for export. You should see “Driver in D...” for each driver in your system listed. Up to 6 drivers can be exported at once.
    9. Select “Export” and export the impulse response as IEEE mono or stereo WAV file.
    ​Click image for larger version  Name:	dataurl482062.png Views:	33 Size:	25.3 KB ID:	927390 ​
    ​EQ APO Process
    1. Open the EQ APO Configuration Editor and configure the rack:
      1. Preamplifier - use to set master gain to avoid clipping audio signal.
      2. Copy channels - Use copy channels to copy the left and right audio to other channels used for the crossover configuration. For example, a 3 way you might use L and R channels for bass, SL and SR for midrange, and RL and RR for tweeter, so we must copy the L channel to SL and RL, and the R channel to SR and RR.
      3. Select channels - use to define the channels to apply a specific filter to.
      4. Convolution with impulse response - load the IR file for your driver here.
      5. Repeat channel selection and convolution filter for each driver in your system.
    2. Verify that each impulse response is loaded correctly using the analysis panel at the bottom, and select each channel to cycle through each filter transfer function.
    3. Adjust the preamplifier if needed to ensure that all responses for all channels are shown at <0dB level. Responses >0dB will be filled in with red to appear obvious.
    4. That’s it, play some music and enjoy! An example configuration is provided below.
    Click image for larger version  Name:	dataurl592553.png Views:	7 Size:	72.0 KB ID:	927391 ​Click image for larger version  Name:	dataurl599592.png Views:	7 Size:	29.0 KB ID:	927392 ​
    Example 3-way Configuration:
    Preamp: -10.8 dB
    Copy: SL=L RL=L SR=R RR=R
    Channel: L R
    Convolution: project2 IR Driver in D1.wav
    Channel: SL SR
    Convolution: project2 IR Driver in D2.wav
    Channel: RL RR
    Convolution: project2 IR Driver in D3.wav
      Posting comments is disabled.
    Latest Articles
    • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
      by theSven
      By Jon Hancock
    • Cult of the Infinitely Baffled
      by theSven
      IB- F.A.Q.
      1)What's an IB?
      For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
      2)Which space is best?
      Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
      15 December 2024, 12:17 Sunday
    • How to: Measure with REW for Room EQ
      by Reet
      REW is a powerful tool, as is EQ, but getting it right can be challenging. The first step to achieving a good EQ profile for your space is to take in-room measurements. This document will detail an easy method to achieve quick and reliable results.
      For room EQ, a single measurement at your listening location will not produce a good depiction of the overall room response. An average of many measurements around the listening area should be completed to create a room response for equalization...
      12 April 2023, 10:42 Wednesday
    • Minimum Phase and Accurate Crossover Simulation
      by Reet
      Minimum phase for a speaker can be described of the phase of the frequency response of the speaker at it’s acoustic centre, or the phase without any excess phase or “time of flight” included. It can be calculated from the speaker’s frequency response using Hilbert-bode transform, or HBT. When comparing multiple minimum phase responses, we can say that the responses occur at the same point in space, ie. there is no physical distance between them. When measuring speakers and processing the...
      26 December 2022, 14:27 Monday
    • How To: VituixCAD Extended Impedance Model For Any Driver
      by Reet
    • How To: Measuring impedance and T/S with ARTA/LIMP
      by Reet
      With a simple jig, loudspeaker impedance and T/S parameters can be easily measured with LIMP. The same jig may also be used to measure component value for resistors, capacitors, and inductors, as well as measure transfer functions of passive and active filters.
      The setup is quite simple, the following diagram is taken from the LIMP manual:
      https://artalabs.hr/download/LIMP-user-manual.pdf
      Measurement Jig ​
      This instruction is following what is in...
      26 December 2022, 14:02 Monday
