VituixCAD Extended Impedance Model For Any Driver
  • How To: VituixCAD Extended Impedance Model For Any Driver
    Many Scan-Speak drivers include this data in the “advanced parameters” section of their datasheets, however the parameters can be extracted from any datasheet that includes a plot of the driver impedance. This instruction will provide the steps required to extract this information for use in the enclosure model in VituixCAD.
    ​Step 1 - Tracing the manufacturer data
    VituixCAD includes a tracing tool that we can use to create the data sets we need. With the manufacturer’s PDF open, the simplest method is to us the Windows snipping tool. Simply press Windows Key + Shift + S, then draw a box around the chart.
    In VituixCAD, go to tools -> SPL Trace. Then under the edit menu, select paste. The tool is fairly straight forward from there, you simply mark some low and high known reference points on the image for the X and Y axis. For impedance, use the y axis amplitude on the right. Then simply click the trace button, then on the line to trace it. If the image is black and white, you may need to erase some grid lines around the plot line for the tracing feature to succeed.
    Click image for larger version  Name:	dataurl444901.png Views:	31 Size:	57.5 KB ID:	927415
    ​Trace Example​
    ​Once you have traced the driver impedance, simply export the result.
    ​Step 2 – Add the driver to the Enlosure Database
    Start by opening the enclosure tool, create a new driver and enter the T/S Parameters from the datasheet.
    Click image for larger version  Name:	dataurl505363.png Views:	12 Size:	24.6 KB ID:	927416
    ​T/S Parameters Example​
    Step 3 – Extract extended impedance data
    We can take the driver parameters a step further and use the traced impedance to determine a extended Z model for more accurate representation of the driver impedance in simulation. Select “Calculate T/S”, then load the traced impedance file under “Free air impedance response”. Provided that you have entered all the other T/S parameters already, simply press the “solve” button under the Extended Z model section. You will see a trace that should overlap the loaded impedance with a high degree of accuracy. Pressing the solve button a few times may achieve a slightly better result.
    Click image for larger version  Name:	dataurl542584.png Views:	12 Size:	73.6 KB ID:	927417
    ​Extended Z model calculation​
    When complete, click “Apply” to save the result to the driver parameters.
    To use the extended inductance model in simulation, simply right click on the SPL chart and select “show effect of inductance”.
    Click image for larger version  Name:	dataurl574099.png Views:	12 Size:	28.2 KB ID:	927418
    ​Show effect of inductance​
      Posting comments is disabled.
    article_tags
    Latest Articles
    • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
      by theSven
      By Jon Hancock
    • Cult of the Infinitely Baffled
      by theSven
      IB- F.A.Q.
      1)What's an IB?
      For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
      2)Which space is best?
      Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
      15 December 2024, 12:17 Sunday
    • How to: Measure with REW for Room EQ
      by Reet
      REW is a powerful tool, as is EQ, but getting it right can be challenging. The first step to achieving a good EQ profile for your space is to take in-room measurements. This document will detail an easy method to achieve quick and reliable results.
      For room EQ, a single measurement at your listening location will not produce a good depiction of the overall room response. An average of many measurements around the listening area should be completed to create a room response for equalization...
      12 April 2023, 10:42 Wednesday
    • Minimum Phase and Accurate Crossover Simulation
      by Reet
      Minimum phase for a speaker can be described of the phase of the frequency response of the speaker at it’s acoustic centre, or the phase without any excess phase or “time of flight” included. It can be calculated from the speaker’s frequency response using Hilbert-bode transform, or HBT. When comparing multiple minimum phase responses, we can say that the responses occur at the same point in space, ie. there is no physical distance between them. When measuring speakers and processing the...
      26 December 2022, 14:27 Monday
      by Reet
    • How To: Measuring impedance and T/S with ARTA/LIMP
      by Reet
      With a simple jig, loudspeaker impedance and T/S parameters can be easily measured with LIMP. The same jig may also be used to measure component value for resistors, capacitors, and inductors, as well as measure transfer functions of passive and active filters.
      The setup is quite simple, the following diagram is taken from the LIMP manual:
      https://artalabs.hr/download/LIMP-user-manual.pdf
      Measurement Jig ​
      This instruction is following what is in...
      26 December 2022, 14:02 Monday
