Do It Yourself - DIY
  • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
    By Jon Hancock
    Go to post
  • Cult of the Infinitely Baffled
    IB- F.A.Q.
    1)What's an IB?
    For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
    2)Which space is best?
    Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
    Go to post
  • How to: Measure with REW for Room EQ
    REW is a powerful tool, as is EQ, but getting it right can be challenging. The first step to achieving a good EQ profile for your space is to take in-room measurements. This document will detail an easy method to achieve quick and reliable results.
    For room EQ, a single measurement at your listening location will not produce a good depiction of the overall room response. An average of many measurements around the listening area should be completed to create a room response for equalization...
    Go to post
  • Minimum Phase and Accurate Crossover Simulation
    Minimum phase for a speaker can be described of the phase of the frequency response of the speaker at it’s acoustic centre, or the phase without any excess phase or “time of flight” included. It can be calculated from the speaker’s frequency response using Hilbert-bode transform, or HBT. When comparing multiple minimum phase responses, we can say that the responses occur at the same point in space, ie. there is no physical distance between them. When measuring speakers and processing the...
    Go to post
  • How To: VituixCAD Extended Impedance Model For Any Driver
    Go to post
  • How To: Measuring impedance and T/S with ARTA/LIMP
    With a simple jig, loudspeaker impedance and T/S parameters can be easily measured with LIMP. The same jig may also be used to measure component value for resistors, capacitors, and inductors, as well as measure transfer functions of passive and active filters.
    The setup is quite simple, the following diagram is taken from the LIMP manual:
    https://artalabs.hr/download/LIMP-user-manual.pdf
    Measurement Jig ​
    This instruction is following what is in...
    Go to post
  • How To: Mirror EQ with VituixCAD
    With VituixCAD, we have the ability to provide a mirror EQ function, that can then be passed to APO EQ for active processing. This allows for a speaker's frequency response to be fully compensated for without requiring many bands of parametric EQ.
    ​VituixCAD Process
    Connect each driver and EQ blocks in the crossover section as shown. Ensure that the active peak/notch filters are “shorted” so that only the G(f) block is directly connected to the driver. Three PEQ blocks are show,...
    Go to post
  • How To: Filter Simulation with VituixCAD and EQ APO
    With meticulous passive filter design, it may be beneficial to hear the result before spending money on crossover parts and putting in the time to assemble the crossover. Fortunately, with VituixCAD and EQ APO and filter can be simulated digitally. This process can simulate multiple drivers simultaneously, one driver for each output on a soundcard, for example a 7.1 soundcard could simulate a stereo 3 way system utilizing 6 channels.
    Note that an emulated passive filter will reproduce...
    Go to post
  • Dual Channel Measurement Jig
    Here's a schematic for a simple dual channel measurement jig, which can be used with ARTA, REW, or SoundEasy. This jig is made with USB audio interfaces in mind, so the use of 1/4" TRS connectors is recommended for this purpose. Main reason is that the 48V phantom power on audio interfaces is only present on the XLR pins, so use of TRS will ensure that 48V will only ever be present when a mic is connected, not when using this jig even if you leave phantom power turned on.
    R1 should...
    Go to post
  • Single vs Dual Channel Measurements, or why friends don’t let friend use USB mics
    What does single channel or dual channel measurement really mean, and what are the implications of choosing one over the other? This document aims to help answer this.
    Strictly speaking, a microphone is a single channel of audio input, in that it is a mono signal. USB microphones which include integrated ADC and USB codec can be considered a single channel device.
    Dual channel would be a measurement which includes a second channel of signal input in addition to the microphone....
    Go to post
There are no articles in this category.
Please log in to your account to view your subscribed posts.
Latest Articles
    by theSven
    By Jon Hancock
    by theSven
    IB- F.A.Q.
    1)What's an IB?
    15 December 2024, 12:17 Sunday
    by Reet
    12 April 2023, 10:42 Wednesday
    by Reet
    26 December 2022, 14:27 Monday
    by Reet
    by Reet
    Measurement Jig ​
    26 December 2022, 14:02 Monday
