Measuring impedance and T/S with ARTA/LIMP
  • How To: Measuring impedance and T/S with ARTA/LIMP
    With a simple jig, loudspeaker impedance and T/S parameters can be easily measured with LIMP. The same jig may also be used to measure component value for resistors, capacitors, and inductors, as well as measure transfer functions of passive and active filters.
    The setup is quite simple, the following diagram is taken from the LIMP manual:
    https://artalabs.hr/download/LIMP-user-manual.pdf
    Click image for larger version  Name:	dataurl683749.png Views:	27 Size:	23.3 KB ID:	927408
    Measurement Jig ​
    This instruction is following what is in the LIMP manual linked above, which is also recommended material for more information
    1. ​Before measuring with LIMP, there is a basic calibration process that should be completed. First, go to setup -> audio devices and make sure LIMP is configured to use the your audio interface, and preferably with the ASIO driver. For example, on my USB interface it says "Yamaha Steinberg USB ASIO". Make sure that "loopback" remains unchecked at all times in the driver settings. If your USB interface includes a “mix” knob, it should always be fully clockwise to the "DAW" or “playback” to ensure that none of the input signal is mixed with the audio output from the computer. Adjust gain as needed.​
    2. Go to setup -> measurement. Here you enter the reference channel, the resistor value, sample rate, FFT size, averaging, etc. Set the resistor value to the specific resistance as measured with your multimeter, sample rate of 96kHz, and the other options as desired.
      Click image for larger version  Name:	dataurl754428.png Views:	7 Size:	18.0 KB ID:	927409
      Measurement Settings
    3. Press the "CAL" button in LIMP. This calibration process will adjust for the difference in gain between left and right input channels. Anytime the gain knobs are touched, or if the FFT size or sampling rate is adjusted in LIMP, the calibration process must be completed. Simply connect the probes as shown in the above diagram, but leave the speaker disconnected. In the calibration window, there is a "generate" button that will create a tone so you can set the level of the test signal, then simply press the calibrate button. It should provide you with a success notification as well as the channel difference.
      Click image for larger version  Name:	dataurl825652.png Views:	8 Size:	25.3 KB ID:	927410
      ​Calibration​
    4. ​It is important to compensate for the test leads from the jig to the speaker. This is detailed in section 4.7.2 of the LIMP manual for reference. To compensate for the test leads from the impedance measurement probe to the driver, simply disconnect the driver and short the leads together. Your amp will be safe with this operation as long as the resistor is connected as it should be. Now simply run the measurement, select "PN PINK" under the generator drop down, Fstart of 10Hz, Fstop of 40000Hz, then press the red "play" button. This will measure roughly 0 ohms, but there will be some resistance and inductance of the test leads. Click on the “fit” button to zoom in on the measured result, then click on the graph at 1kHz to set the cursor location, then press the "RLC" button, which will provide you with the lead resistance and inductance parameters. Write these numbers down.
      Click image for larger version  Name:	dataurl874490.png Views:	8 Size:	31.3 KB ID:	927411
      ​Lead Compensation ​
    5. Now, press the "cable compensation" button, which is just to the right of the "CAL" button. Enter the resistance and inductance measured, and check the box to enable the compensation. For the example above, I would enter 0.1029 ohms, and 2470 nH. Now, if you rerun the shorted lead test, the measurement should be incredibly close to 0 ohms across the entire spectrum.
    You are now fully set up and ready to measure speakers, or resistors, capacitors and inductors too! Just connect the driver or component as shown in the diagram above and run the measurement. PN PINK noise test is quick, however lacks some accuracy at very low frequencies, so if you find your measurement is noisy at low frequency, you may have to run the stepped sine instead. In LIMP, unfortunately it is a slow process, but the accuracy is very high.
    For driver free-air T/S measurement, it is important that motor vents are unobstructed, so placing face up on a desk may not be the best solution without some block spacers to keep the vent open. For complete driver T/S, two measurements must be completed, one with added cone mass to determine the VAS of the driver. For this process, simply take the first measurement and export it as the driver free air impedance, then also select overlay -> set as overlay curve. Now some mass needs to be added to the driver cone so get out your kitchen scale. If you have a spec sheet for the driver, the added mass should be about equal to the driver Mms or "moving mass", so the moving mass is being doubled for this process. If you don't have the datasheet for the driver, loop up the Mms of a driver of similar size and cone material. The idea is to lower the Fs of the driver by 25% so use that as a guide on the mass requirement as well. Run the measurement again, you will see the added mass measurement now as well as the free air overlay. Export this measurement, its good practice to include the added mass used in the file name.
    ​The T/S parameters can be calculated within LIMP, or the exported measurements can be used directly in VituixCAD to complete the calculations there as well.
    In LIMP, simply select analyze - loudspeaker parameters - added mass method. The voice coil resistance should be measured with your multimeter and entered, as well as the driver diameter and added mass used. The diameter here is determining the "Sd" parameter for radiating surface area, and it is generally measured as the cone diameter + half of the surround. In the "nonlinear LSE optimization" section of this window, check the top and bottom boxes, but not “estimate voice coil resistance Re”, and in the dropdown for the lossy inductor model, select "Le + L2||R2||K" which is more commonly known as the "semi-inductance" model, and in VituixCAD it is referred to as the "Extended Z model".
    Click image for larger version  Name:	dataurl933874.png Views:	6 Size:	52.0 KB ID:	927412
    ​T/S Calculation in LIMP​
    One convenient feature here is that you don't have to manually enter these values into VituixCAD. If you press the "copy parameters" button here, then in VituixCAD enclosure section, press the + button to create a new driver, you will find a "paste" button in the lower left corner to simplify the process.
    T/S parameters can also be calculated directly in VituixCAD. All the same information is required - 2 measurements of free-air and added mass, and you must enter the specific added mass and driver diameter. When you create a new driver in VituixCAD, simply press the "calculate T/S" button, and enter in all the necessary information. I won't go into great detail here as I feel it is fairly straight forward.
    Click image for larger version  Name:	dataurl965518.png Views:	6 Size:	80.5 KB ID:	927413
    ​T/S Calculation in VituixCAD ​
      Posting comments is disabled.
    Latest Articles
    • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
      by theSven
      By Jon Hancock
    • Cult of the Infinitely Baffled
      by theSven
      IB- F.A.Q.
      1)What's an IB?
      For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
      2)Which space is best?
      Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
      15 December 2024, 12:17 Sunday
    • How to: Measure with REW for Room EQ
      by Reet
      REW is a powerful tool, as is EQ, but getting it right can be challenging. The first step to achieving a good EQ profile for your space is to take in-room measurements. This document will detail an easy method to achieve quick and reliable results.
      For room EQ, a single measurement at your listening location will not produce a good depiction of the overall room response. An average of many measurements around the listening area should be completed to create a room response for equalization...
      12 April 2023, 10:42 Wednesday
    • Minimum Phase and Accurate Crossover Simulation
      by Reet
      Minimum phase for a speaker can be described of the phase of the frequency response of the speaker at it’s acoustic centre, or the phase without any excess phase or “time of flight” included. It can be calculated from the speaker’s frequency response using Hilbert-bode transform, or HBT. When comparing multiple minimum phase responses, we can say that the responses occur at the same point in space, ie. there is no physical distance between them. When measuring speakers and processing the...
      26 December 2022, 14:27 Monday
    • How To: VituixCAD Extended Impedance Model For Any Driver
      by Reet
      by Reet
      Measurement Jig ​
      This instruction is following what is in...
      26 December 2022, 14:02 Monday
