Dual Channel Measurement Jig
  • Dual Channel Measurement Jig
    Here's a schematic for a simple dual channel measurement jig, which can be used with ARTA, REW, or SoundEasy. This jig is made with USB audio interfaces in mind, so the use of 1/4" TRS connectors is recommended for this purpose. Main reason is that the 48V phantom power on audio interfaces is only present on the XLR pins, so use of TRS will ensure that 48V will only ever be present when a mic is connected, not when using this jig even if you leave phantom power turned on.
    R1 should be at least a 5W resistor, and the rest can be small 1/4W resistors. the 1K resistor R5 ensures that the common ground of both the audio interface and amplifier are at the same potential. A spreadsheet it attached to aid in part value selection for the probe voltage divider resistors R2/R3/R4/R5.
    You will notice that this jig doesn't include a "calibration" switch. To calibrate, simply disconnect the speaker from the jig.
    To switch from impedance measurements to SPL measurements, simply flick the switch, disconnect the impedance probe and plug in your mic. Reference probe remains connected at all times.
    WARNING: Do NOT use this jig with internally bridged amplifiers, such as many low cost "chip" amps. Amplifier must not be bridged so that the negative speaker terminal is a neutral common.
    Click image for larger version  Name:	image.png Views:	0 Size:	36.8 KB ID:	927385
    Speaker acoustic measurement configuration.
    Click image for larger version  Name:	diagram SPL.png Views:	601 Size:	37.7 KB ID:	953405
    Speaker impedance measurement configuration.
    Click image for larger version  Name:	diagram IMP.png Views:	501 Size:	37.5 KB ID:	953406
    Click image for larger version  Name:	arta jig.jpg Views:	0 Size:	758.3 KB ID:	927386
    Click image for larger version  Name:	20210119_210804.jpg Views:	0 Size:	655.9 KB ID:	927387
    A photo of the internal wiring. It may not look very pretty, but it does the trick perfectly well.
    Click image for larger version  Name:	image.png Views:	0 Size:	1.32 MB ID:	957226
    [Edit Feb 2025: Updated with photo of ugly internal wiring. Added spreadsheet attachment to aid in voltage divider value selection.]​
      Posting comments is disabled.
    Latest Articles
    • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
      by theSven
      By Jon Hancock
    • Cult of the Infinitely Baffled
      by theSven
      IB- F.A.Q.
      1)What's an IB?
      For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
      2)Which space is best?
      Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
      15 December 2024, 12:17 Sunday
    • How to: Measure with REW for Room EQ
      by Reet
      REW is a powerful tool, as is EQ, but getting it right can be challenging. The first step to achieving a good EQ profile for your space is to take in-room measurements. This document will detail an easy method to achieve quick and reliable results.
      For room EQ, a single measurement at your listening location will not produce a good depiction of the overall room response. An average of many measurements around the listening area should be completed to create a room response for equalization...
      12 April 2023, 10:42 Wednesday
    • Minimum Phase and Accurate Crossover Simulation
      by Reet
      Minimum phase for a speaker can be described of the phase of the frequency response of the speaker at it’s acoustic centre, or the phase without any excess phase or “time of flight” included. It can be calculated from the speaker’s frequency response using Hilbert-bode transform, or HBT. When comparing multiple minimum phase responses, we can say that the responses occur at the same point in space, ie. there is no physical distance between them. When measuring speakers and processing the...
      26 December 2022, 14:27 Monday
    • How To: VituixCAD Extended Impedance Model For Any Driver
      by Reet
    • How To: Measuring impedance and T/S with ARTA/LIMP
      by Reet
      With a simple jig, loudspeaker impedance and T/S parameters can be easily measured with LIMP. The same jig may also be used to measure component value for resistors, capacitors, and inductors, as well as measure transfer functions of passive and active filters.
      The setup is quite simple, the following diagram is taken from the LIMP manual:
      https://artalabs.hr/download/LIMP-user-manual.pdf
      Measurement Jig ​
      This instruction is following what is in...
      26 December 2022, 14:02 Monday
