Single vs Dual Channel Measurements, or why friends don’t let friend use USB mics
Latest Articles
  • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
    by theSven
    By Jon Hancock
  • Cult of the Infinitely Baffled
    by theSven
    IB- F.A.Q.
    1)What's an IB?
    For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
    2)Which space is best?
    Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
    15 December 2024, 12:17 Sunday
  • How to: Measure with REW for Room EQ
    by Reet
    REW is a powerful tool, as is EQ, but getting it right can be challenging. The first step to achieving a good EQ profile for your space is to take in-room measurements. This document will detail an easy method to achieve quick and reliable results.
    For room EQ, a single measurement at your listening location will not produce a good depiction of the overall room response. An average of many measurements around the listening area should be completed to create a room response for equalization...
    12 April 2023, 10:42 Wednesday
  • Minimum Phase and Accurate Crossover Simulation
    by Reet
    Minimum phase for a speaker can be described of the phase of the frequency response of the speaker at it’s acoustic centre, or the phase without any excess phase or “time of flight” included. It can be calculated from the speaker’s frequency response using Hilbert-bode transform, or HBT. When comparing multiple minimum phase responses, we can say that the responses occur at the same point in space, ie. there is no physical distance between them. When measuring speakers and processing the...
    26 December 2022, 14:27 Monday
  • How To: VituixCAD Extended Impedance Model For Any Driver
    by Reet
  • How To: Measuring impedance and T/S with ARTA/LIMP
    by Reet
    With a simple jig, loudspeaker impedance and T/S parameters can be easily measured with LIMP. The same jig may also be used to measure component value for resistors, capacitors, and inductors, as well as measure transfer functions of passive and active filters.
    The setup is quite simple, the following diagram is taken from the LIMP manual:
    https://artalabs.hr/download/LIMP-user-manual.pdf
    Measurement Jig ​
    This instruction is following what is in...
    26 December 2022, 14:02 Monday
