Low cost IR solution for Zone 2 (UK vendor)
  • Eiffel
    • 57
    For people who are looking for a relatively low cost solution to control the Zone2 output of Rotel pre-amps and receiver, I'd liketo recommend the IR kits from Keene electronics (A UK company which sells a distribution amplifier, 2 emitters and receiver for about GBP 40).
    It worked right out of the box with my RSX-1055 (I just needed a stereo 3.5m jack cable to go between the one of the 4 low power outs of the distribution amplifier and your Rotel component).
    In case you're curious, I have a fairly long connection between the IR DA and my receiver, but have no problem whatsever (the connection goes through two 10+ meter runs of basic Cat5 cable, a distribution panel, RJ45 wall outlets, etc... I'm actually able to use the same RJ45 cables to bring line level stereo sound to my zone 2 room, without hum or a balun, which is very good news).
    I'm not affiliated with keene electronics, and decided to try their product given its low cost compared to better known brands... but I think that some people would be interested in this product
    Eiffel
    • 16478
    That's pretty cheap for what you're getting :T
    • rarmand
      RSP-1572 Optical 1 to Zone 2 #FAIL
      by rarmand
      First timer here.
      I have an RSP-1572 processor mated to an RMB-1506 distribution amplifier.
      I'm having trouble playing OUT to Zone 2 from my Airport Express plugged into Optical 1.
      Here's where I'm at:
      • I know Optical 1 works — I can plug...
      04 January 2015, 19:29 Sunday
      Proposal for an easy to build modular multi vendor bass bin concept for music
      by Evil Twin
      Introduction
      Many impressive small monitor projects have been presented on the pages of HT Guide and other publications, with the concept that, if you mate this with a good "bass bin" concept for music, you will have an exceptional high performance system. The proposed Ascent...
      19 September 2014, 10:33 Friday
      IR distribution
      by Andrew Pratt
      So what's the scoup on distributing IR signals from one room to another? I've seen everything from hard wired to Powermid IR to RF to IR type systems. I only need to pass along a signal from my living room to the basment HT room so we can control the CD juke box from upstairs. My Rotel has inputs for...
      05 July 2002, 11:12 Friday
    • weepus
      zone 2 on integra 4.5 help!?
      by weepus
      Ok, i'm about at wits end here.
      To simpify what im doing, I'll only refer to three components.
      1) The zone 2, which is just a CRT tv with composite video and simple two channel stereo... basicly, its just a tv. I'm not using Coax to feed it any signal, just the composite video and sterio...
      07 April 2007, 18:50 Saturday
    • starford
      Figured out Zone 2 operation on C 1
      by starford
      Well, I finally figured out how the Zone 2 thing works on my C1. I reported earlier that operation of Zone 2 appears to be impossible from the front panel, because pushing the Zone button appears to do nothing but show the message "Zone Off", and in this I was wrong. The change I was missing...
      22 September 2003, 11:05 Monday
