Help: How to connect 1068 pre to Marantz Receiver.
  • HTguy
    • 13
    I bought the Rotel 1060/1075 combo to replace my Marantz AVR SR7000. The F/C/S are driven by the 1075. I would like to use the SR7000 to drive the 2 Center Back speakers until I can afford the 1080. Is it possible to accomplish this ? How do I connect the 1068 CB1/2 output to the Marantz SR7000.
    thanks,
    HTguy
  • Scherr
    • Dec 2003
    • 91
    Plug the Rotel surround back preouts (using an RCA cable) into any two of the 6 channel inputs (i.e., SL & SR). Set the Marantz to external input or whatever would be used for DVD-Audio/SACD. Set the volume to "0" reference level on the Marantz.
    I am doing this with a Rotel 1056 and my old Denon 2800 and it works like a charm.
    You can also power a second zone. Use the second zone preouts into the FL and FR external inputs. All you need is an additional set of speakers and you can power a second zone. I am doing this as well.
    Scott
    • HTguy
      • 13
      Thank you much much. Your second zone answer is actually my next quesiton. Thank you very much for reading my mind and provide answer.
      HTguy
      Scott
        Any reason to switch from a Marantz SR7000 to a SR7400?
        by audioqueso
        Hello everyone.
        I just bought a Marantz SR7000 from ebay to power my B&W 601s (upgraded from an old Onkyo TX-DS575x). I wanted to get a Rotel RSX-1056, but money changed, so I had to go with something under $700. I listened to a Marantz SR7000 with my speakers and found them to...
        07 December 2004, 20:24 Tuesday
      • swams
        B&W 704 fronts with Marantz SR5001 bi-amp setup
        by swams
        I was previously borrowing a Marantz SR7000 from a friend hooked up to my B&W 704 speakers. He needed it back, so I went out and bought a new Marantz SR5001, because I didn't want to spend the money on something like a Rotel RSX-1057. At first I was really disappointed with the SR5001... it sounded...
        25 October 2006, 13:27 Wednesday
      • Scherr
        Second Zone Bleedthrough
        by Scherr
        I noticed that if I have my second zone on the same input as my main zone, that even with the second zone off, there is still sound playing through the second zone speakers. Turning the second zone on makes the sound louder. Turning the second zone off makes it fainter, but still noticeable.
        13 November 2004, 15:36 Saturday
      • gostan
        Any Way To Have 1055 Internal Amps Power Second Zone?
        by gostan
        Two days with mynew rsx-1055 and I have several questions. I do need a second amp to power my zone 2. I would like more power on the main channels. Since I have to purchase a second amp for zone 2 and since I got such a great deal on the 1055 (3 months old - traded to my dealer) I was wondering why...
        30 June 2003, 05:35 Monday
      • Aussie Geoff
        1098 Wish List and Need for a 1099!!!
        by Aussie Geoff
        In researching “wish list” requests for the 1098 I’ve started to develop a sense of what can be realistically added to the 1098 as is and what would require a major hardware upgrade. I thought this worth sharing, since it will provide a context for the next version of the 1098
        27 October 2003, 09:52 Monday
