Help with Rotel problem
  • Fresh_Burn
    • Oct 2004
    • 9
    Hello everyone, I have owned Rotel products for about 6 months now and I am happy with the performance that it gives me, but recently a few days back I notice that my settings keep going back to Zero or default, like the sub level goes to 100 while I had it set at 80, the tone goes back to zero, and it does not read my coaxial cable set to coaxial 1 from the receiver to the dvd, it's very frustrating because I have to set it back to my preffered settings over and over. I am running these with a Monster Power Center HTS 3500 MKII with everything connected there. I usually press the on/off switch when not in use, I have been doing this for the last 6 months and I did the software upgrade to V2.26 for the receiver. I have not known if there were power fluctuations in the last few days but it's suppose to protect the equipment that I have even though without a Voltage stabilizer. Am I doing something wrong here or should I have the Power Center on at all times?Is this safe with the Rotels? I have wrote to MonsterCable but it seems that they're Customer Service does not correspond very well and I emailed Rotel and I am still waitng for an answer from them. Please help if you have encountered these problems because it's a bit of a pain when you see your gear resseting like that and not knowing where the problem is. Thanks in advance. ops:
  • Fresh_Burn
    • Oct 2004
    • 9
    Help
    • Taito
      • 226
      Mate, I'd love to help, but unfortunately I don't own one of what you are having problems with, but it would help others help you if you told us what model your rotel unit is, and also what is connected to it.
      Aside from emailing Rotel, have to talked to your dealer??
      -Ben
      • Fresh_Burn
        • Oct 2004
        • 9
        This is my system set-up, Rotel RSX-1055, RMB-1075, RDV-1060, speakers B&W CM6,CM4 and CMC and Hsu-VTF3-MkII all connected through the HTS 3500 Monster Power Center. I't just keeps resetting to zero and I have to do it manually all over again to set the settings. Did anyone ever had this?
        • Aussie Geoff
          • Oct 2003
          • 1914
          Fresh Burn,
          Take the RSX-1055 in to your dealer. Sounds to me like either the EPROM battery (if the RSX-1055 has one) or the ERPROM itself is faultly - either way the dealer can repair for you..
          Geoff
          • JOY DIVISION
            • 152
            BIOS problems?
            • soundhound
              • Mar 2004
              • 816
              As Aussie Geoff said, those are volatile settings that are held by a battery when power is removed, so I would be willing to bet your'e battery has expired.
              • Fresh_Burn
                • Oct 2004
                • 9
                I've just spoken to Mike Sheehan of Rotel and he told me it might be a power outage that might have caused it, either way I told him about the memory might be affected and he told me just get it checked with the dealer and it's still under warranty. Thanks guys.
                  Twin Moderator Emeritus
                  • 16706
                  Good old Mike. He's an awesome guy to deal with :T
                  • tempest
                    Newbie needs help - Rotel quality driving me nuts
                    by tempest
                    Hi Folks,
                    I'm a newbie hear looking for some help and encauragement. I purchased a Rotel RSX 1055 receiver just before Christmas. All was fine until about 2 or 3 months ago. One morning after turning on my home theater the front left speaker started popping loudly. To the point where...
                    29 May 2004, 12:31 Saturday
                  • nadroj29
                    PLEASE HELP help Rotel RSP 1098 serious issues!!!!!
                    by nadroj29
                    If your taking the time to read this please continue I NEED HELP....g
                    God im about sick to death of buying expensive electronics and having them go out on me... i previously posted questions regarding my brand new Rotel rsp 1098. Now i came home today and tried to use my also garbage blue ray...
                    10 November 2006, 00:42 Friday
                  • Alex999
                    Please help; Rotel and b&w, not sure what to do
                    by Alex999
                    Hey guys,
                    I just purchased a pair of B&W 805S speakers (they should be delivered in few days). I have a Rotel RMB-1095 amp, Rotel RSP-1066 preamp and RDV-1040 DVD/CD player. When I got my original components I was planning to go 5.1 set up but things changed and I use my system for 2ch stereo...
                    05 October 2008, 19:55 Sunday
                  • NeilGabriel
                    HELP Rotel RSX 1067 screwed it up
                    by NeilGabriel
                    I got this used, but think I caused the problem. When I set it up, I stupidly plugged the multichannel audio outs from my BR player into the multichannel outs of the receiver instead of the ins.
                    When played, the receiver went into max volume that could not be turned down until it hit...
                    24 November 2010, 15:31 Wednesday
                  • stanleyleecm
                    Rotel RA02 intergrated Amp set-up and help!!!
                    by stanleyleecm
                    I just got a RA02 last week, I have to say that it is great and sounds really good compare to what I have before (yamaha RXV-1300). I paired up the RA02 with NHT SB2 and a Denon 1710. And all I have is a RCA interconnect connecting my int-amp with my dvd.
                    My question is am I using the...
                    27 July 2005, 01:37 Wednesday
