HELP...hooked up 1056 to 1080=no sound
  • pdr711
    • 35
    Just purchased a 1056 and a rb1080. Very happy untill I turned it on. I have the front speakers going to the 1080. I have the pre out FRONT L and R from the 1056 going to the unbalanced preout of the 1080. I get no sound coming from the 2 front speakers.
    I hooked the front speakers up directly to the 1056 and they work. Am I doing something wrong or do I have a defective 1080?
    Dan
  • Taito
    • 226
    Hi Dan, just a thought... check that your 1080 is not set to receive a 12V trigger signal (switch on the back). If it is, your power light will still be on, but the amp itself will be on standby (unless it has 12V trigger connected) - hence no sound.
    Hope this helps, Ben
    • Azeke
      • Mar 2003
      • 2123
      Do you have 12V triggers?
      Check your menu settings, to ensure the proper location triggers are activated.
      Also, check you manual, the trouble-shooting section. It may be a simple menu setting, esp. audio settings.
      Azeke
      • pdr711
        • 35
        Thanks so much, it was the 12v trigger problem.
        Now I have another problem. I had the OSD up once but now can not get it to reappear. I am not getting any sound when I choose to listen to dvd player or sat.
        Thanks for your help
        Dan
        • theMaximus
          • 179
          Dan
          There should be a OSD button on your remote (RR-1050) that is labeled M. As for no sound from DVD or satellite, you may need to explain your set-up (how they are connected to RSX-1056, etc...) in more detail before anyone can help you.
          Victory Shall Be Mine!!! :heh:
          • pdr711
            • 35
            Thanks Maximus, OSD is working. I had to press aud key then osd key.
            I have the dvd player connected to the 1056 by optical cable through the vid 2 input on the 1056. I then went to the osd and changed the input to vid 2 with input optical 2. I now have sound.
            I did the exact same thing with my satellite except I used vid 1 input and optical 1 in the osd. My sat is a Hughes dvr not a hd though. It is connected to the 1056 by optical cable into vid 1. I still have no sound. I elected to use optical connection so I can receive DD 5.1.
            any other ideas about what I am doing wrong?
            Dan
            • theMaximus
              • 179
              Dan
              I seriously doubt if there is anything wrong with your optical cable, but it may be worth the try to switch the two optical cables you are using to see if the no sound problem follow one cable. Also, try a digital coax instead if your Hughes sat. receiver has that output. Also, try other audio inputs in Video 3 and Video 4 in your 1056.
                • 16478
                Some sat receivers only output via the digital connection when there's a 5.1 source playing otherwise they revert back to analog so you might have to also connect the analog cables into the video 1 jack.
                  Twin Moderator Emeritus
                  • 16706
                  I ran in to that problem with my digital cable STB. I also ran in to the problem that the STB puts out a "blank signal" even when no digital signal is present so I couldn't use my 1066's automatic select feature to default to analog unless a digital signal was detected as there was always a digital signal even with no actual audio info. Needless to say I was a little :M but I worked around it with my touchscreen remote. Still annoying that I had to set it as two seperate components though :evil:
                  • pdr711
                    • 35
                    Andrew, you are correct. My satellite was reverting to analog. I could only get sound if the movie that was playing in true dd 5.1( i.e. HBO movie). I ran a simple rca red & white along with an optical. I now have sound through the sat. I hate sounding like a dumbA** and not knowing what to do. The Rotel is a little different to setup than my old Yamaha.
                    I do appreciate all of the help.
                    Dan
                    • ropotamo
                      12V triggers connection
                      by ropotamo
                      During last month I have bought following components: RSP 1098 (3 x12V trigger + zone2), RMB1095 (one in and one out) driving center, two surrounds and two surround backs, RB 1080 (one in and one out) driving fronts, RT 1080 (one in and one out), RDV 1060 (one in) and RCD1072 (one in). How to connect...
                      25 January 2004, 16:23 Sunday
                    • june
                      12v triggers?
                      by june
                      hello all,
                      can the 12v triggers 1 & 2 be assigned on the rsp 976? i hve this option on my rsp 1068. but can find how to assign the triggers on the rsp 976 on screen menu.
                      17 November 2007, 07:42 Saturday
                    • Henk
                      RSP 1098 12v trigger problem
                      by Henk
                      I use two 12v triggers on my RSP 1098, one triggers a RLC-1050 power distributor (which in turn powers on a RB-1090) while the other triggers a RMB-1075. Everything worked fine until a few weeks ago when the RSP 1098 started to interrupt the 12v trigger to both components at random after power on. When...
                      10 April 2004, 04:32 Saturday
                    • benjamj
                      12v trigger question
                      by benjamj
                      I know there have been several threads on 12v trigger issues, so I hope you will indulge me. I have an Onkyo receiver with pre-outs and 12v triggers for 2 additional zones. I am using an old 5-channel receiver to power those 2 zones, and have dedicated 2 channels per zone. The old received lacks a 12v...
                      06 December 2011, 18:44 Tuesday
                    • Audio Junkie
                      RB1091 12v trigger replacement
                      by Audio Junkie
                      Hi All, my first post! I'm a long time Rotel fan
                      I have 2 RB1091 amps which I got a deal on from my local dealer several years ago. At the time he said the 12v triggers weren't working. At the time this wasn't a problem for me. However since upgrading my system late last year I now want to...
                      21 January 2021, 16:26 Thursday
