I use two 12v triggers on my RSP 1098, one triggers a RLC-1050 power distributor (which in turn powers on a RB-1090) while the other triggers a RMB-1075. Everything worked fine until a few weeks ago when the RSP 1098 started to interrupt the 12v trigger to both components at random after power on. When this happens I have to power off the 1098 and power on again. The triggers then work for a while until, unexpectedly, the signal gets interrupted again. Most annoying. I've tried all four triggers, checked the settings and loaded the 1.1.8 software. Problem remains. All components work fine without the 12v trigger, but these must now be powered on manually.
Anyone having similar problems or know what the cause can be?
