Hi List - Has anyone experienced problems with the RR-1050's interoperation with the RSP-1066. I have one recurring problem - the OSD menu only comes up intermittently when the button on the RR-1050 is pressed. I am using the composite output to monitor to OSD as directed. Additionally, I switch back to AUD before trying to access OSD (ie, I'm not trying to access when sources such as from DVD, CD or other are selected). It seems like OSD will function the first time it is requested, then thereafter seems to be very intermittent. I have reset and reloaded the remote as well - OSD seems to function the first time after a reset, then reverts back to its intermitent mode.
I am running RSP 1066 SW ver 2.2.4 - I don't think that any further updates affect the remote operation.
ANY CLUES OUT THERE? Thanks - Mark
