Hi @. I also posted this on the AVS Forum (hope that isn't bad form!), but I'd be really interested in the views of Rotel fans (maybe not so impartial though :W )
I'm in the market for a receiver & after some demos have narrowed the choice down to the Denon 3805 or Rotel 1056. Here's the catch...I have a couple of Cyrus power amps (1 x Q-Power, 1 x Power). I can afford to either buy the Denon & keep the power amps, or buy the Rotel & Ebay the power amps (here in the UK the Rotel is about £400 more expensive).
Now, I haven't been able to demo the Denon with my power amps driving the front channels, so I'm not really sure just how much improvement I'd get, plus I've had to demo the two units at different shops as nobody seems to have both. As the Q-Power cannot be switched to mono (but the Power can), I'd have to use the Power for the centre channel & the Q-Power for the front L/R. I understand that the processing in the Denon is top class (better than the Rotel?), but the Rotel tends to generally get better reviews over here as a higher quality unit overall.
I'd be really interested to hear any comments/thoughts about either of these two units & my little dilemma. Thanks!
One of the trademarks of Rotel is that they tend to over build their power supplies..even in things like CD players etc as they (and many others) believe you can't build a quality component with out a strong power supply as a backbone.
