1066 problems and solution
  • jprzybylski
    • Feb 2003
    • 24
    I loved my 1066 from day one.
    What I didn't love was the unacceptable signal recognition delay that ranged from 1 second to up to 12 minutes before the unit would recognize a signal, decode it and begin playing it. I also didn't love the occasional "pop" that would happen at various times in playback.
    After almost 3 weeks of putting up with this, I decided to return the unit -- and was hopeful that I wouldn't have to send it in for service and would just get a new one.
    My wish was granted, and I just brought home a brand new 1066.
    Upon inspection, not only was the delay and popping problems fixed, but there were a couple other surprises that I didn't get in my original 1066 box.
    A new remote with better features:
    My original remote had only one remote power button, that -- when programmed -- would act as a toggle on/off for the appropriate device. This new remote has discrete on/off buttons for easier operation for customized buttons.
    It also has a few discrete surround format buttons, like 2-channel, Dolby Pro Logic Music, and Cinema as well as quick-button for 5 channel and 7 channel stereo decoding.
    Selecting inputs on the new remote is also a lot more intuitive. They are all on the top of the remote now, instead of being hidden under the slideable bottom panel.
    This new remote does not tell time, no big shakes, since I have many clocks around my house anyway. Also, the LED screen readout is slightly larger, the window itself is not larger, the text is.
    Computer Upgrade cable:
    The new unit also came with the cable needed to upgrade to the most current version firmware -- which I'm also happy to report that the unit came shipped with 2.2.4 - the most current is 2.2.5, so I'm happy with 2.2.4 for now.
    I wish I'd known this before I spend the money to make my own cable to upgrade my previous unit.
    This new unit recognizes signals faster (and I gave it a rigorous workout switching from DTS cd's to HDCD to DVD Audio to DVD movies and regualr CD's) There is sometimes a 2 second delay at most, but that is worst case scenario.
    There still seems to be a longer delay when decoding *some* HDCD's but, at least now I can hear the THX logo from the beginning and now 5 seconds into it.
  • Scarp
    • Mar 2003
    • 632
    Great that its working now
    I've got a brand new RSP-1066 and also got the RR-1050. I had to get used to the huge size of it. But its a good remote.
    • KMD
      • Apr 2003
      • 30
      Joe After I read your post I went to my boxed up remote control and saw that it was a RR-969 was this the same as yours? How long ago did you buy your unit? THx
      • suarez
        • Jan 2003
        • 32
        hi,
        i have never seen the rr 1050 before.
        could someone send or post a picture from this remote?
        rr1050@globalcontrol.org
        thx
        suarez
        sind sie ein eichenmann?
        • jprzybylski
          • Feb 2003
          • 24
          KMD --
          Sorry -- but I have no idea what the remote was before I returned the unit -- I never had a problem with the original remote. So I wasn't that preoccupied with getting a new one.
          The best way to distinguish the old one versus the new one is the power button. If the power button on your remote is one long button that just says "power" then it is the old one. The new one has two separate buttons, the word "power" is written above them: one button says "on" and one the other button says "off".
          Also, there is no "flippaple" cover underneath the slide-open compartment.
          Hope this helps -- a note to Rotel -- you should offer current customers the option to upgrade to this new remote for free since this remote is much better.
          • jprzybylski
            1066 delay problems
            by jprzybylski
            This is my umpteenth post about this problem, and hopefully someone from Rotel will see this. Because based on many threads I've read on this site, ALOT of people have this problem and have just come to accept it.
            I purchased a 1066 and am happy with the sound quality, but there is a...
            16 April 2003, 20:02 Wednesday
          • opus
            1066 delay
            by opus
            Hey Guy and Gals,
            Back again for hopefully another simple question.
            I always noticed a audio delay when using my rsp 1066 and also having the audio coming from the tv when watching HD programming. The 1066 was always a little ahead of the tv but this was easily fixed...
            15 August 2006, 18:00 Tuesday
          • dallaskruse
            Rotel 1066 - Zone 2 - Remote Control
            by dallaskruse
            Products: Rotel 1066 and RR-969 remote Control
            I am at the tail end of adding a Logitech Harmony to my parents' Home Theater.
            They have a Rotel 1066 receiver along with the Rotel RR-969 remote.
            Zone 2 works great when accessed via the front Zone button on...
            19 October 2014, 09:59 Sunday
          • Madd
            1066 questions & thoughts
            by Madd
            Well, I am new to Rotel and new to this forum. This looks like the forum to get some knowledge for Rotel gear. My questions are is that I got this unit 1066 with the 1075 on Dec 22 for my Xmas present to myself. Holding down the mute button= V2.2.2 02/09/05. Well, this unit does not decode Dolby Digital...
            14 January 2003, 08:56 Tuesday
          • radim
            remote control RR-1050
            by radim
            I have one little problem. On my remote don't function buttons at the bottom> clone, edit, learn. Why ? I can't programming, cut off sound, ...
            Thanks, Radim
            21 March 2004, 11:08 Sunday
