RB-1050 and Anthem Compatability Issues...Please Help
  • Evan Scussel
    • Jan 2003
    • 11
    Recently I sold my Anthem MCA-5 power amp to upgrade two channel performance. The amp I ordered for main L/R is on order and I decided to buy a used Rotel RB-1050 to power surround speakers down the road, but until my main amp arrives, the RB-1050 is my main amp. I bought it used.
    Immediately after hooking it up to the Anthem the sound was horrible. Flat, lifeless, with no real dynamics. I was sure it was a connection problem.
    After checking the connections and running numerous tests, here is what is happening. It almost seems as if the signal is "filtered" to the amp...like the output from the Anthem isn't full strength to the Rotel. The reason I deduct this is that at low volumes (around 50db) the Rotel will actually engage auto shut off from the signal triggering feature, even though the signal is clearly audible, even from 10 ft away. I know the gain on the amp is completely full. I also know the input impedance on this amp is less than my previous amp, so there should be no adjustment needed to the output gain in the Anthem to the amp.
    I have hooked this amp directly up to my Sony SCD-555ES by adjusting the gain in the Rotel down and I get the sound I am looking for, clear, dynamic and effortless.
    I had my previous amp hooked up via XLR and cannot run the Rotel that way because of the fact that it only accepts RCA. I know that a full calibration is in order because running RCA results in a 6db signal loss. I have already done this.
    I was just wondering if anyone else had this combo and experienced anything similar. For those of you who have this amp in conjunction with other processors, do you notice the amp engaging in shut down at volumes that would normally be much greater than what you would expect for this behavior to trigger?
    Normally I would say the Anthem is at fault here because it seems fine when I run the amp direct to the source, but the fact the amp shuts off automatically is disconcerting. My previous amp also had a signal trigger and it NEVER shut off automatically in 15 months of use no matter how faint the signal. It literally wouldn't exhibit this behavior unless I had NO signal engaged.
    Of course I really cannot tell if it's the amp or the processor or a combo of the two until the order for my main amp comes in. Until then I am looking for suggestions. Thanks guys.
    Weird.
    Still searching for that elusive "perfect" sound.
  • Legairre
    • Jan 2002
    • 231
    Evan,
    I won't have my 1050 until Saturday, but Levesque(who's a forum member) has one mated with the 1095. Maybe you can give him a shout.
    Oh yeah, BIG TIME congrats on being a moderator. With your passion for music, and knowledge of Anthem gear they couldn't have choosen a better guy.
    "What do you mean it's too loud? My ears aren't even bleeding yet!"
    Radden Home Theater
    Radden Home Theater
    • audiofreak7
      Which Amp? ANTHEM!!! Hands down
      by audiofreak7
      Hi fellaz,
      I see a LOT of people on this forum discussing amplifiers, And I must ask.........does anyone know what Signal to Noise ratio is? Cuz it doesn't seem like anyone does. And before I go on, this is NOT a matter of opinion....it is proven fact. S/N ratio is the strength of the...
      13 February 2005, 16:37 Sunday
    • rick c
      Rsx1056 and rb1050 ?
      by rick c
      I have an rb1050 just laying around right now and was contemplating adding it to my rsx1056.The rsx1056 is rated at 100x2,the rb1050 70x2.Would it even be worth the trouble adding the 1050 to the rsx1056 for the fronts.Would i notice anything being the amp is rated lower.I just hate to get to the rear...
      03 January 2008, 15:35 Thursday
    • brian.hillier
      Anthem Statement D1
      by brian.hillier
      Has anyone out there heard when the Anthem receivers will be getting HDMI switching? I was also wonderering if these receivers will be able to handle the Dolby TrueHD and equivenent formats in their true form since the software is upgradeable, or does this require a hardware upgrade as well?
      31 January 2006, 11:20 Tuesday
    • mike c
      RB1050 power ratings
      by mike c
      in the online brochure it states that the RB1050 has 50wpc
      in the online manual it states 70wpc
      both at 8 ohms.
      which one is it?
      where do you guys get the ratings for 4ohms for all the rotel amps?
      what rating does the 1050 have on 4 ohms?
      does it mean...
      06 April 2006, 18:35 Thursday
    • Mukaudio
      Rotel / Anthem / Outlaw for amp
      by Mukaudio
      I'm currently using a Marantz 5400 AVR to drive Paradigm Studio 100 fronts and CC-570 center. I've had the Marantz since I started this expensive hobby with a pair of Mini-Monitors. Now that I'm up to the big boys, I feel like I need some more power.
      My dealer has recommended both Rotel...
      29 December 2005, 18:41 Thursday
