RSP-1066 loud popping & hissing sound after 11/2 hours
  • Max Goh
    • 5
    Recently, I encountered a problem with my Rotel RSP-1066 unit that really upset me. What happen is after watching a movie in Dolby Digital/DTS for about 11/2 hours, the processor just went silent for about 2 secs and then loud hissing and popping sound occurred. When this happen, I changed source input (e.g. VCR) and back again, everything become normal for less than a minute and problem resume. I went to check test tone when this happen but no sound at all. After I powered the unit down using the master switch and turn it on again, everything is back to normal but problem came back again after a while. When the unit is completely cold down, everything works again for about 11/2 hours and same problem occurred.
    I sent my unit to the agent but they could not fault it and told me to change the digital board which is very expensive. As such, I have decided not to do so and brough my unit home. I borrowed a cable from the shop I bought the unit from and download the latest firmware V2.26 but to no avail - problem is still there.
    Anyone that can help me resolve this problem will be very much appreciated.
    Regards
    Max Goh
  • eelco74
    • Dec 2002
    • 394
    Rotel comes with a 5 year warrenty. Since the unit is only max 2 years old, it must be repaired under warrenty.
    Bring it back to your dealer and get it fixed.
    Marantz AV8802, Marantz UD8002, Rotel RB-991 and RB985mkii, Rotel RD960
    Focal/Jmlab Electra 1028S, Electra CC, Electra SW1000S, Cobalt 705
    Pioneer KRL-37V, Epson EH-TW8100, Kinkping CES-180 77"inch
    • Max Goh
      • 5
      Hi Eeelco
      Thanks! Unfortunately, I bought this unit in Singapore and it only came with a 1 yr warranty.
      Cheers!
      Best Regards
      Max Goh
      • Ross Smith
        • 43
        I just a RSP 976 replaced because when changing from analogue to a digital source or changing TV stations on my STB sometimes I would get this very loud digital static noise or crackling noise. It sounds similar to your noise, the dealer didn't tell me they found wrong just a suspected faulty DSP board. I'm pretty happy as the replacement was a new RSP 1066, but now that gives a slight crackling sound when in digital mode, when you make any adjustment to the menu or change channels on the STB or chapters on the DVD player, I hope the 2.6 firmware fixes it.
        • Max Goh
          • 5
          Hi Ross
          Thanks for the information. I have just been requested by Rotel dealer in Singapore to send in my unit for further troubleshooting. If they need to replace the DSP board, it will be VERY expensive and since this unit is slightly over a year old when the problem occurred, I don't think it is worth to pay for the replacement. If that is the case, I might seek ROTEL head-office assistance to see if they can provide a FOC board replacement.
          Cheers!
          Best Regards
          Max Goh
          • madmac
            popping noise then no sound (RSX-1056)
            by madmac
            Hey all,
            Recently I've been getting a loud popping noise out of all speakers from my Rotel receiver and then there is no sound from any source. If I turn it off and then on again, it operates normally for a bit, pops again and then no sound. I cleaned, spliced and reconnected all patch...
            03 August 2010, 08:22 Tuesday
          • Polk-Ey
            A Hissing Polk
            by Polk-Ey
            Just a question concerning one of my speakers. I use Polk Audio RT-1000i Loud speakers and was wondering about a suspicious hissing sound that came from it a day ago while watching a movie. I was watching Predator and at the end if you know, theres a huge explosion where the monster blows away half...
            26 December 2004, 15:28 Sunday
          • efarstad
            My New SVS 25-31Pci
            by efarstad
            I'm just a simple guy who loves HT. Like many I heard A LOT about SVS and their subs...then I saw that their new PCi line was coming out. I pre-ordered one of their 25-31PCi's and waited patiently.
            Then the day came...my UPS tracking number! I couldn't wait to see if the Sub would live...
            23 April 2002, 13:24 Tuesday
          • egaither
            Humming, hissing and popping won't go away
            by egaither
            So I just purchased all new Rotel goodies recently. Hopefully with some background you guys can lend me hand. I purchased the 1098 along with the 1095 and my speakers are Klipsh Reference series...efficient but also quite revealing speakers. I had a Yamaha RX-V1400 receiver originally...no hum and then...
            16 May 2004, 02:21 Sunday
          • Bing Fung
            What is Humming, Hissing & Popping?
            by Bing Fung
            Hey All,
            What is with all the noises I've been reading that Rotel's can be afflicted with?
            I'm looing into a Pre/Pro and Amplifier package. However I would like to know more about all these noises the Rotel Pre/Pros may have and how a firmware may fix it, or if you turn...
            16 May 2004, 13:27 Sunday
