Multi-Part: (Tuner & interconnects and pricing)
  • WallaceBW
    • Jan 2003
    • 78
    Hello All:
    I am currently a Rotel-less HT fanatic that is looking to replace my failing reciever (don't ask it's too embarasing) with a 1066/1075 combo.
    The questions are:
    What tuner sounds good with the 1066 (the 1080 seems odvious but I had to ask)?
    What Interconnects are you you all using from the 1066 (or other pre/pro) to your amp?
    And in todays market what is concidered competive pricing on the 1066 and 1075 AND 1080? If you can include sources on this it would be great because One of my HT shops told me to "see me last so I can beat their pricing".
    One last thing:
    other than the fancy lcd (won't use it so don't care) and additional inputs (can't see ever needing them while the unit is still a viable solution) and dsp um stuff (don't use/like dsp much)... what makes the RSP-1098 so appealing for additional projected cost?
    Thanks In advance,
    WallaceBW
    • 16478
    For interconnects I highly recomend CatCables They're all I try to use for critical runs (silvercats and coppercats) For connecting lower signal quality components like the VCR or Sat DSS I use either Radio Shack gold's or Acoustic Research which are decent quality low cost cables. For my CD player and mains though silvercats is all I'll use.
    If a tuner is important to you I'd consider not getting the 1066 but getting a 1055 receiver instead and use it as the pre amp. You'll loose a wee bit in sound quality but you'll gain the tuner. From my listening tests in my system these too models are so close it was impossible to tell them apart but on paper there are differences. The 1055 as a pre amp though is becoming a very popular choice since it adds more flexibility then the 1066.
    What seperates the 1098 from the 1066 should be sound quality and upgradeability (swapping cards) and the new remote.
    • Rock Dog
      • Jan 2003
      • 417
      Being new to this end of the spectrum. I was wondering whether I should use the balanced or unbalanced input of my 1095? (when it comes in ) Can I even connect the 1066 to the balanced input? And are there cables to accomplish this?
      -Thomas-
      The easiest way to find something lost around the house, is to buy a replacement.
      Hey You! Make sure you stop by the HTguide Off-Topic section. It's FUN!!!
      -Thomas-
      As long as people will accept crap, it will be financially profitable to dispense it.
      Hey You! Make sure you stop by the HTguide After Midnight section. It's FUN!!!
      • WallaceBW
        • Jan 2003
        • 78
        Thanks... The Tuner is not all that important to me (in fact I don't plan to buy it imediately because I tend to listen to the radio only about 2-3 times a year (from my HT setup that is) I will most likely realize that I don't need it at all... Other that the integrated tuner are there any advantages to the 1055? Also, loosing sound quality (even a wee bit) is a hard thing for me to do intentionally
        Another quick one... Are all of the 1066's being sold the 100Mhz+ models (hi video bandwidth) or should I be careful to specify...
        Thx again,
        WallaceBW
        • Danbry39
          • Sep 2002
          • 1584
          Be careful. I'm sure there are still some out there with the 10Mhz video switching. As far as cables go, I use mostly Rhino and Signal. However, I've heard Andrew post so enthusiastically about his "cats" that I'm going to look into them next time, although I do really like the ones I have. I figure I'm going to still be replacing one power cord and up to ten analog interconnects. Was thinking of going Signal again, but I'll probably at least check out Andrew's pet cable brand. Everything I've heard about them is superb. I'll also put a plug in for Transparent, whose cables I love, but, so far, only own one power cord.
          Keith
          Keith
          • WallaceBW
            • Jan 2003
            • 78
            Are there any independent reviews of the CAT cables? Also some more specs on the copper and silver purity would be nice I.E. 99.99% OFC yatta yatta... you should send a pair to Secrets of Home Theater and High Fidelity...
            I've always liked their reviews...
            What can I say I like Specs :LOL:
            WallaceBW
            • Nicholas Renter
              • Jun 2002
              • 57
              I use StraightWire Encore II interconnects with...
              Denon DVD-2500
              Rotel RSP-1066
              Rotel RMB-1095
              Rotel RQ-970BX
              (4) B&W Nautilus 805s
              (1) REL Strata III
              Straight Wire: manufacturers of Audio/Video cable and wire components for multimedia home theater and hi fi audiophiles or enthusiasts.
              From the StraightWire web site:
              For Dolby Digital Receivers, separate power/pre amp systems, D/A outputs, better DVD & DSS units, and high quality integrated amps & tube electronics.
              Level 3 cables by Straight Wire offer unique benefits such as:
              Copper strands that are individually polymer coated during extrusion to minimize corrosive effects of air and moisture.
              Advanced fabric braids to control resonances and reduce microphonics. All electrical and mechanical parameters have been optimized in our laboratory for real-life performance in your home.
              Encore II utilizes the highest grade of foam insulation for astonishing midrange fidelity. Our most advanced Star-Quad design, Encore II outperforms all other cable designs in this price class and insures high compatibility with nearly all components. Discover the significant improvement a Level 3 cable can make with Encore II wired throughout your system. XLR (balanced termination available)
              For interconnects, I found the price quite reasonable. But what I think is reasonable, you may feel is overpriced or not "up to par".
              I haven't heard the CatCables, so I can't really comment on them.
              • WallaceBW
                • Jan 2003
                • 78
                I use StraightWire (currently) for my Component Video run of 3M and 1M Digital audio (RCA/Coax type). Yes the cabes are good... but pricey for the quality. I am thinking about the cat cables (once I hear some more info about them). Just looking for bigger bang for my buck than straightwire
                Also, all that technology is great (and CAN work well) but the past has taught me to be weary... Some of the best results are obtained by using a copper of silver conductor (solid) and uninsulated (due to the fact it is ridgid and will not bend and short out -- and air in a better insulator than even teflon) bent into shape. This actually goes against some conventional wisdom... It is impractical yes... Would I use it... No.. I'm just proving a point
                WallaceBW
                  • 16478
                  I haven't seen any "professional" reviews of the catcables but if you look around there's plenty of us amatures that have nothing but praise for the ones we've purchased...I also don't think they've ever had a cable returned which speaks to their quality.
                  Anyway as to using ballenced connections there's no point using ballenced connections to the 1055, 1066 or 1098 since they don't have ballenced in/out puts.
                  • WallaceBW
                    • Jan 2003
                    • 78
                    Ok... Thx for the info... I think that I'll try them... but which one?
                    BlueTiger
                    Silvercats
                    or
                    concertcats?
                    This is between a 1066 and 1075 if it helps...
                    Also I still beed current pricing on the 1066,1075,and 1080 (I may open a new thread on these topics though...
                    Brian
                      • 16478
                      If music is important to you I'd go silver for the front mains at least with copper for the remaining channels (opting for silver on the centre if budget allows) Email Doug (owner) and see what he can do for you...he might have some special pricing that he can do for a bulk order.
                      As for pricing the 1066 should be around $1200 US with the 1055 coming in a little cheaper then that (~$1000). Not sure on the amp
                      • WallaceBW
                        • Jan 2003
                        • 78
                        I'm new and thus aren't familiar with the customs of this forum... If you'd prefer that I don't create additional threads to try to isolate each topec into a thread let me know... but most places prefer this.
                        Brian
                          • 16478
                          No new threads are good...helps to keep things on track
                          • fyonn
                            • Nov 2002
                            • 28
                            well, I'm using a sony std-777es tuner with my setup and it sounds great, but it might not be a useful option in the US as the main reason it's so expensive is that it's a digital radio as well as fm.
                            dave
                            • Alex Prosak
                              • Jan 2003
                              • 7
                              Check out audioadvisor.com, they have some excellent prices on the MIT Terminator line. I believe the line has been phased out but they're still good. I'd recommend the MITerminator 2.
                              • Rock Dog
                                • Jan 2003
                                • 417
                                Well... Mr. Pratt. I must say that Doug at Cat Cables is a breath of fresh air in today's "crap laden" customer service environments.
                                Many companies make high-end, quality cables. But dealing with a guy like Doug, who takes the time to answer my questions, reponds in a very reasonable amount of time to email, and is flexible with orders that don't quite fit into his ordering structure, is a very nice surprise. Not to mention the little added perks here and there.
                                Cat Cables has my current and future business. Thanks for the tip.
                                -Thomas-
                                -Thomas-
                                  • 16478
                                  now you know why he has as many fans as he does...wait till you see the cables...you won't want to hide them behind your gear.
                                  • WallaceBW
                                    • Jan 2003
                                    • 78
                                    I plan on picking up 5 1M Silvercats with the usual connector only with rhodium coating... a 0.5M cable would be cutting it way too close with my current setup.
                                    Brian
                                      • 16478
                                      you guys keep this up and we'll need to open a club catcables
                                      • WallaceBW
                                        • Jan 2003
                                        • 78
                                        A shop near me quoted me at 12% off retail on rotel gear... (I'll check them out)
                                        • efarstad
                                          • Jun 2001
                                          • 2230
                                          Brian, that's sweet buddy! Let us know how you like the Cats!
                                          E
                                          The Norwegian A/V Nut!
                                          E-Cinema
                                          E-Cinema
                                            • 27460
                                            Rock Dog (Thomas), and Wallace (Brian), thanks guys for your orders of CATs and the nice comments! Your orders will be a produced and ready to ship on Monday.
                                            Thanks again,
                                            Owner
                                            CATCables.com
                                            • WallaceBW
                                              • Jan 2003
                                              • 78
                                              Great...
                                              Thanks for the update,
                                              Brian
                                              • Nicholas Renter
                                                • Jun 2002
                                                • 57
                                                Wait a minute..."Lex" is actually the owner of CatCables AND a mod on this site?
                                                So what's your affiliation to Rotel, Andrew?
                                                I'm begining to get suspicious...
                                                  • 16478
                                                  Yes Doug (lexman) owns both quatum and catcables as well as co owns this board along with mats.
                                                  I have zero affiliation with Rotel other then I own one of their products and wanted to set up an area here to talk about them. When questions started coming in that I didn't know the answer to I emailed Rotel and over time have become friendly with serveral people over there...that's all there is too it.
                                                  If you're implying that I'd recomend a cable just because doug owns them you don't know me very well. I don't suggest products I haven't tried or own unless I'm damn sure its a solid product since if its not what I say it is my name is on the line and in this online world we don't have much other then our name and reputation. I've stood up for some products I think are worth fighting for and called other crap...if Rotel's new DVD player doesn't do as well as the Panasonic RP82 I'll be the first to say so....I always call a spade a spade.
                                                  • efarstad
                                                    • Jun 2001
                                                    • 2230
                                                    Nicholas: Andrew is talkin' the truth...He's called me a Spade before! :B
                                                    No worries...hangin' out on this board you will see "no bashing" "no arrogance" and "just guys trying to help each other!" That's what attracted me to this forum...guys bein' "real" with each other. If it was anything other...I'd be out of here man! And that too...is callin' it a Spade!
                                                    E
                                                    E-Cinema
                                                    E-Cinema
                                                      • 16478
                                                      Erik I thought I called you a dork not a spade :LOL:
                                                      • efarstad
                                                        • Jun 2001
                                                        • 2230
                                                        My bad...that's right...I'm a DORK, not a spade! Thanks for reminding me buddy...what a good memory you have! :P
                                                        D-arn
                                                        O-outrageous
                                                        R-ightgeous
                                                        K-ing
                                                        :-y
                                                        E
                                                        E-Cinema
                                                        E-Cinema
                                                        • Nicholas Renter
                                                          • Jun 2002
                                                          • 57
                                                          Sorry, Andrew. I don't mean to offend. I just get a bit suspicious when advice comes from a person / site / magazine has a vested interest on how favorably a product is presented / reviewed.
                                                          This is why many of us rely on these type of sites for unbiased opinions. How can you believe a review in Stereophile when the manufacturer of the reviewed product takes out a full page ad in the issue where a favorable review is published? You can't. And I don't.
                                                          I always believe that full disclosure is best. I don't mean to question your integrity, but as a moderator, I would have expected you to disclaim that another moderator at this site is the owner of the company that manufacturers the product in question, and that that company is also a sponsor of this site.
                                                          Please don't take offense any to this. I'm just trying to ask the appropriate questions for the benefit of all. I'm sure you meant well...I'm not paranoid. It's just everyone is out to get me.
                                                          Again, apologies.
                                                          Nicholas Renter
                                                          • efarstad
                                                            • Jun 2001
                                                            • 2230
                                                            ;-x Just mow um down Nicholas!!!They're out to get me too! :2guns:
                                                            In all seriousness though...your questions are right on and should be asked. So don't apologize...
                                                            Once you've become fully integrated into the Guide, we'll start sending you money too...I mean...make you say positive...ur...uh....forget it...they said I was not supposed to talk about the secret "code." :B
                                                            (For those who don't know me....I'm KIDDING! :P )
                                                            Keep asking whatever questions you or anyone wants to...we don't shy away from truth and honesty hear...PERIOD!!!
                                                            E
                                                            E-Cinema
                                                            E-Cinema
                                                              • 27460
                                                              Nicholas, allow me to clarify. HTGuide was established first. I am the founder. I own half of this forum though, as I have a technical partner, Mats. Consequently, almost everyone here during HTGuide's beginning, knew that I owned CATCables. Because it was born from here after we'd been a forum for a year. Andrew's been a long time customer of CAT. He receives no pay from CAT Cables or HTGuide. So, really, he has no incentive other than the fact we are friends to help CATCables. Most importantly, he's been happy with the use of his cables, so that is the dominant factor in his decision to support CAT. Kevin Patz, Eric, and others have no affiliation with this forum or CAT but still recommend CAT. So, please, understand there was nothing intentional, and in fact, I have posted to other threads here as owner of CAT, and as Admin. So, nobody is trying to hide anything. Least of all me. If you note the MatrixAV.US in my signature, you will see all my affiliations. That's a pretty open declaration.
                                                              Further, you will find that I will go the extra distance for all my customers. But I'd certainly never turn my back on a Guide member. So, that puts the dual affiliation as really a positive, not a negative.
                                                              As to Andrew's relationship with Rotel, no one here receives money from Rotel, not even advertising revenue. Andrew bought Rotel gear, loved it, and suggested we start the Rotel area. It's really a wonderful thing, not a bad thing he's done for everyone here. And I am happy, because lots of members have joined us, and that's what we've needed for a long time, a nice influx of members.
                                                              Thank you,
                                                              Doug (Lex)
                                                              Owner
                                                              HTGuide, CATCables, Quantum Cable, Zeus Cable, The Cable Forum.
                                                              Cable Guy DVD Collection
        • 16478
        no problem nicholas open dialog is never a bad idea. Doug and I don't always agree on everything and when I don't I'm not afraid to tell him how I feel. Like it or not I usually tell it like it is. If you'll notice in most of my posts in threads requesting cable recomendations I don't usually recomend all catcables for all components...sure we'd all love to have a complete catcables set but lets be honest some devices don't really need that level of cable and when bugets are fixed as they are for most of us choices have to be made...anywho if you have any questions feel free to email me.
        • Ron67
        Input on RSX-1065 vs 1066/1075 combo?
        by Ron67
        Well I've been auditioning everything under the sun for a couple of months now and I keep coming back to the RSX-1065 combined with B&W DM604 S3 mains, LCR600 Center (maybe...) and the DM601 S3 Rears. They're an awesome match! Nice and clear but not shrill or overly forward with plenty of 2 channel...
        12 May 2003, 23:23 Monday
        • pbarata
        Annoying cross-talk between analogue inputs (Tuner/CD/Tape) in RSP-1066
        by pbarata
        In my current set-up I’ve a Rotel RCD-1070 player connect via CD analogue input on RSP-1066. If then a select the Tuner (without anything connected to the respective input) and then increase the volume I can hear...
        02 September 2003, 10:17 Tuesday
        • terry78
        Long Interconnects and Rotel
        by terry78
        Has anyone used really long interconnects (about 25 feet) with the RSP-1066? I'm thinking of adding an RB-1050 and a pair of center rear speakers to my RSP-1066/RMB-1075 combo to get a full seven channel system. I could put the new amp back by the speakers and use a 12 year old pair of Straight Wire...
        21 May 2003, 16:05 Wednesday
        • keiron99
        Digital throughput on 1066
        by keiron99
        I hope I can explain this clearly:
        I have acquired a DAC for my hifi which I want to use for my stereo music listening as it provides higher quality replay than the 1066. I will connect my source to the DAC digitaly, then connect the lineouts of the DAC to the 1066 (in effect just using...
        21 December 2005, 12:05 Wednesday
        RSP-1066 / RSX-1055 etc. Frequently Asked Questions (FAQ)
        by Andrew Pratt
        Rotel has a FAQ available here that may answer some of your questions. We've added several points of our own as well below.
        1. How do I know what firmware is installed on my processor?
        Answer: Simply press and hold the mute button on the remote and it will be displayd on the LCD...
        15 April 2003, 14:08 Tuesday
