I have a Rotel RSX-1560 that won't power on. I plug it in and turn on the master switch in back (and smile to myself as the light in the room flicker) and the unit appears to come on in standby mode (power light surrounding the soft button on the front is lit). But when I hit the power button on front - nothing. Has anyone seen this before? All the fuses appear intact. Power button appears functional. Ideas?
Rotel RSX-1560 will not power on
by zmanbandsI have a low usage 1090. Normally in the standby mode the power button is out and all lights are out. When you push the button in to power up, 3 lights go on and in a few seconds two go out leaving the 3rd light on to show the power is on. Well yesterday that 3rd power on light stayed on regardless...-
Channel: Club Rotel
by bokesIs there anyway to Dim the blue ring light around the front power button.
I searched the manual but only found that pressing MENU will turn off display- not the light. (It's very bright in dark room)-
Channel: Club Rotel
by GlennI have temporarily set-up my new RSX-1055 to make sure all is working correctly. It has the latest firmware.
The current set-up is 2 channel. Just the basics for right now. I went into the set-up menu and changed the front main channels to "large". I set all the rest to "none"....-
Channel: Club Rotel
by SLIMaxPowerHi, I just got my hands on a rmd -1075 mk2 and I need to disable the front power button and wire in a makeshift one without cutting/removing anything.
The reason being my youngest child loves turning the buttons on and off on other equipment. I have had to locate my current receiver into...-
Channel: Club Rotel
by pchanjHi,
I was wondering whether someone has experienced anything like this. Just a few weeks ago, after watching a movie. I turned off my amplifier RMB 1075 and heard a loud pop. I cannot really tell if it came from the amp or speaker, but one thing I noticed though was that the protection light...-
Channel: Club Rotel
- Loading...
- No more items.
