I have a low usage 1090. Normally in the standby mode the power button is out and all lights are out. When you push the button in to power up, 3 lights go on and in a few seconds two go out leaving the 3rd light on to show the power is on. Well yesterday that 3rd power on light stayed on regardless of the button in or out ie I could not power the unit off with the button in our out. The unit worked fine to play music whether the button was in or out. Before calling Rotel tech support, who by the way are very good, I decided to unplug the 1090 and in a few minutes plug it back in. Luckily this cleared the problem completely. I share this in case this ever happens to you. My guess is this trick may work on a 990 as well. I have also cleared a mal- function with my Sony S9000Es SACD player by doing this.
Rotel 1090 Power Button/Lights
by d.kozminihsHello there
I have purchased used Rotel RSX-1055 amplifier today and it got some serious issue.
It just won't power up fully. When i push the power button the blue power button goes on like it normally should. Then I press the Power button on a remote - it clicks once,...-
Channel: Club Rotel
by jteoh1Hi,
I just picked up a demo RB-1090 amp from a local dealer; it came with what appeared to be a standard U.S. 110V cord. It is a 14AWG32C gauge cord with pentagonal shape end (wall side). I had a loaner from another dealer recently that had a higher grade cord with a rounded end. ...-
Channel: Club Rotel
by TAYFUR GUNAYDear Rotel lovers
I have a problem with my power amp RB-1090. When I press the front power up button all house lights go off. This problem happens as soon as i press the front button , before front leds light or soft start relay reacts. What would be the problem. I have experienced this problem...-
Channel: Club Rotel
by PewterTAOhhh today is a rough day...
Last night I went to turn off my Rotel RB-1090 amp and when I pressed the button.... well the light stayed on... which I thought was odd. SO my thinking was, I missed pushing in the button all the way and it didn't turn off, so I bent over again and pushed...-
Channel: Club Rotel
by TapeshThere is continuous a krrrrrrrrrrrrrrrr. sound coming from my speaker. Possibly power related issue.
Connections CD Player Sony 555ES -> ASL AQ2004DT -> Rotel RB-1090 -> Polk Lsi9 Speakers
Sound level increases as connections are made. Just speakers hooked on,...-
Channel: Club Rotel
- Loading...
- No more items.
