Is there something wrong with my RC-1590? (high noise floor / white noise)
  • Wanteds13
    • Apr 2021
    Bouncing my head against the wall and hoping you guys have some insight / advice for me.
    I've just treated myself to a RC-1590 preamp for my music listening setup. The rest of the setup is a Rotel RB-1090 power amp, my old but still great and trusted Bowers & Wilkins DM640 floorstanders and a REL Quake MK2 subwoofer to complement the low end (sub's crossover is set to 40 Hz).
    Before the RC1590 I used an Onkyo AVR as preamp (TX-SR705).
    The difference in sound is AMAZING. However, it has an awefull lot of background hiss. The Onkyo had barely any background hiss, I had to put my ears against the tweeter to hear any at all. The Rotel, however, has A LOT of it! I can hear the tweeters hissing from 3 feet away, which quite frankly shocked me... It's even worse if I use XLR cables instead of unbalanced. I can reduse the hiss by flipping the switch on the RB1090 from unbalanced to balanced while still using the unbalanced inputs. This lowers the level of gain, which reduces the hissing considerably. However, there still is some.
    The reason to chose the RC-1590 over the RC-1572, and pay the hefty premium that comes with this choise, is that I had read that the RC-1590 suposed to have a much better SNR and lower noise floor.
    This hiss does not change with the volume, between 1% and 85%. At 0 the amplifier switches off the relay and all hiss is gone. At ~85 and above the hiss rises with volume. Until that point the hiss is at a constant level, independent of volume.
    I've tried disconnecting all sources from the preamp, including my mac that's connected to the USB DAC. Even with just the preamp, power amp and speakers connected there's a verry prominent hiss. I've tried switching inputs, but on all inputs except bluetooth it produces hiss. The only reason it doesn't on BT is that it seems to turns off the output relay when no device is connected or playing while BT is the selected input.
    I LOVE the sound of the preamp, it's much smoother, less aggressive, than the Onkyo. It's buttery smooth, very 'open' and more 'full boddied'. However I'm shocked (and disappointed) by the level of hiss and wonder if maybe there is something wrong with my unit... How can it be that my old Onkyo has a better noise floor than the Rotel. It's suposed to be the best audiophile unit Rotel has to offer (except for the Michi) and has three times the retail price of my old Onkyo - a entry level surround receiver from yesteryears. :huh:
    Are there any others on this board that have this amp and can shed some light on this issue? Does your preamp also hiss or is it just mine?
    Stereo setup
    Rotel RC-1590, Rotel RB-1090, B&W DM640, Rel Quake MKII, NAD C556, NAD C565 BEE, iMac, Chromecast Audio
    HT setup
    Onkyo TX-NR5010, B&W 603 S2 front, B&W LCR6 S2 center, B&O 6000 surrounds, SVS PB10, Panasonic 55CX700, custom build HTPC, Chromecast
    • 4158
    I don't have an RC-1590, but is it possible to plug the pre amp in to a different circuit in your home? I realize your amp would be a beast to have to pick up and haul around, but maybe an extension cord for testing purposes would be sufficient. My thinking is maybe the Rotel is more sensitive to a power issue than the Onkyo. I may be completely off base, but hauling the unit back to where you bought it, and discovering it doesn't do it there, would be frustrating.
    • r100gs
      • 322
      Maybe this will help. https://www.psaudio.com/ps-how/how-to-find-and-fix-hum/
      Jay
      • Wanteds13
        • Apr 2021
        I've been in contact with Rotel (B&W Group). Together with an engineer on the phone we've tried a few things, one of them being trying a different group by using an extension cord. After about an hour he concluded the unit is probably faulty. I've returned it but the shop unfortunatly didn't have another one at stock. Because of the pandemic situation the logistics in getting a new one is a bit tough, a new one would not be with me before June, probably even July. The shop did refund me the full amount I've payed for the preamp. After phoning around for about a day, it seems noone has a black RC1590 in stock.
        I've turned to the used market and bought a used RC-1570, and though I can definatly tell the difference in transparency and openness between it and the RC1590, it doesn't have the non linear noise issue. I think it will keep me happy till the logistics problem is solved. Perhaps I'll even wait till a new model comes out (can't imagine this will be very long, since the RC1590 is already around for about 6 years).
        However, thanks for thinking along!
        Stereo setup
        HT setup
          • 4158
          I hesitated to post, in the hope that someone with more Rotel experience and/or some experience with your issue, would be able to help. Your post looked lonely, though, so I had to try.
          I'm glad you found the problem, and sorry you found it where you did. It's a shame they didn't offer to fix the one you had themselves, or at least point you to an authorized service center for some warranty repair.
          I am happy to hear you at least have something to keep the music playing until you can fully resolve the situation.
            I have owned an RC-1590 for two years and am absolutely delighted with it. It sounded excellent from the moment I switched in on. It is a big step up from my previous RC-1082 which is now doing worthy service in my other system. My RC-1590 is perfectly quiet. Based on my experience and the steps that you have taken I can only suggest that your unit must be faulty.
            • DM3000 Owner
              Preamp for N801's
              by DM3000 Owner
              What kind of preamps have you used with the 800 series B&W's?
              I haved N801's and Bryston 7B St's. I am using a tueb preamp and can now hear some hiss from the tube preamp with the Brystons.
              I want to go SS. Considering Bryston BP25 but have heard mixed reviews....
              19 July 2006, 09:25 Wednesday
            • rotelnyc2
              Yet another question about RSX-1067 hiss/pop
              by rotelnyc2
              Hey all!
              I'm a first time Rotel owner, been eyeing the RSX since the introduction of the 1065. First off, I did find a good amount of info on the hiss/pop issue amongst the threads, but didn't find much info on my questions and issues specifically so I decided to start a new thread,...
              04 March 2005, 07:31 Friday
            • ICEMAN70
              Rotel RSX 1057 with Hiss issues...
              by ICEMAN70
              Hi guy's
              You know, i thought ROTEL would have fixed this problem by now with their Receivers. My New RSX 1057 has the same hissing issue as the 1056 had. You can hear the Hiss from about 3 feet away. But from my listening position you really can't. I sit about 10-11 feet away. But the...
              31 May 2006, 00:36 Wednesday
              Benching the Cambridge Audio 851E Analog Preamp
              This is something I've been wanting to get around to for a while, just to see how this unit that I've been using a while stacks up. As it turns out, there were a few surprises... which should be put into context, and highlight where dichotomies can come up in comparing the audible performance in a typical...
              14 April 2016, 13:05 Thursday
              OnTheBench.key by Jon Hancock, on Flickr
              This is something I've been wanting to get around to for a while, just to see how this unit that I've been using a while stacks up. As it turns out, there were a few surprises... which should be put into context, and highlight where dichotomies can...
              16 April 2016, 22:31 Saturday
