Hello, i need some help.
I purchased a Rap 1580 and I am unable to figure out how to send lfe when playing 2-channel pcm audio.
I have my rotel connected to the shield android tv and a Panasonic ub9000.
I have my rotel speaks set to small with the fronts crossover at 60hz and the center 80 hz and the sub at 120 hz.
For the sub i crossover dial set to max. It's the klipsch rpw10.
No matter what I do, pcm 2 channel audio does not route any bass to the sub. Only when it says dolby digital does it work.
I can fix this if I manually change the processing modes, but I would rather have the rotel do it automatically. Right now the mode is set to source dependent.
I am new to home audio, so I am not sure If this is possible.
I been testing using tidal, dvd rips I own using plex and kodi.
I tested setting the fronts to large and sub to max and that still does not work.
I have the audio for both devices sending their hdmi audio to the rotel.
