sending audio over cat5
  • yellowfin342
    • 12
    Here is my problem.
    I want to send video signal to my projector and sound signal to a remote receiver via cat 5. Both are in the same room, but it was setup for rear projection so the wiring is a little off but Cat5e is avalable to do this if posssible.
    The receiver is a Denon4308CI with Wifi and Ethernet.
    The source is an hd configured/bluray equiped computer with DVI outputs and audio outputs which works great. Problem again is the distance between the computer and the projector and receiver.
    Last edited by yellowfin342; 27 December 2008, 14:59 Saturday. Reason: I left something out
  • yellowfin342
    • 12
    Here is a simplification of the question.
    Is it possible to send SPDIF signal via cat 5e with a special spliced connection using the cat5e twisted pairs ?
    Audio card to spdif output to cat 5e to spdif to receiver. I want to use the existing Cat5e because the runs already exist in the wall.
    • Kevin D
      • 4601
      I wouldn't splice it. You need to pick up some Balun's that convert the 75ohm signal to run over CAT5.
      We use Niles, but there are plenty of manufacturers that sell them.
      Getting HDMI/DVI over CAT5 is a different story. They make them that use 2 CAT5's, but out of the 4 brands we have tried none work.
      Kevin D.
      • yellowfin342
        • 12
        Thanks Kevin
        It's an optical Link which complicates it that much more, prob impossible.
        Any ideas about sending audio signal directly from computer out the rj45 port to the network and then to the receiver on the network ?
        I have never heard of this but never thought of it either ! So it would be playing a blurAY DISC IN THE COMPUTER AND OUTPUTTING AUDIO TO THE NETWORK to the receiver. Possible ?
        bd
        • Kevin D
          • 4601
          I've used an optical to coaxial converter when using CAT5 with only an optical out. I want to say they're around $35.
          There are solutions to send a digital stream over TCP/IP (network), but they are not cheap.
          Kevin D.
          • yellowfin342
            • 12
            Thanks again
            So that solution would be optical to converter to coaxial to Cat5 to coaxial to optical input or the coaxial input on the receiver ?
            If I can use the Cat5 for Audio like that , it would be a good long term solution as long as I use the front projector.
            Manufacturer name ?
              I'm very keen on HDMI extenders out now, over a SINGLE Cat 5 cable. These are emerging products, and several companies were showing new products at CEDIA this year. Gefen just announced their version of it in the last 10 days or so.
              A little limited on range. No experience yet on how well any of them work, but I could definitely use several in my house.
              • Kevin D
                • 4601
                Chris,
                The only HDMI over one CAT5 available right now converts HDMI to component and then back to HDMI on the other end. They don't advertise this is how they do it. Not sure what the other companies are doing, but if they can't get it to work over two CAT5's I'm worried.
                Bill,
                If you have an open coaxial input on your receiver, just use that. It's the same signal, one runs over light one runs over copper. It's a very valid long tern solution. In fact I did it last year to get a PS3 within bluetooth range of the theater and have the audio run up a floor to the equipment closet.
                Digital converter:
                Balun: (need two)
                Send full 6 channel Dolby Digital, dts up to 600 feet. Our Digital Audio Balun (transceiver) allows you to send S/PDIF Digital Audio up to 600 ft. using Category 5 unshielded twisted pair -UTP. The advantage of using our transceivers is that you can go beyond the 35 ft. limitation of S/PDIF digital audio using a coaxial cable. You simply splice a Cat 5 cable, select a pair of wires, insert each wire on one of the screw terminals and repeat the process on the other end...using the same pair of wires, of course. The VideoEase_ Digital Audio Balun allows a digital audio source to be connected up to 600 feet (183 meters) away from a digital audio decoder/amplifier via copper unshielded twisted pair (UTP). Used in pairs, the Digital Audio Balun allows a digital audio source such as a DVD, VCR or satellite receiver to be connected via copper twisted pair to a digital audio home theater system. The Digital Audio Balun connects directly to the digital audio equipment's "Coaxial" input (usually a black RCA jack) and features two screw terminals and a built-in cable strain relief for ease of installation and reliable connectivity. Applications include home theater systems; schools; concert halls; auditoriums and convention halls; arenas; parks; airports; and hotels. Features & Benefits - Supports Dolby Digital, dts - Up to 600 feet (183m) via Cat 5 UTP - Cable strain relief - Compact design - Gold-plated RCA connector - Lifetime warranty - Design patent pending Availability: Ships same day. Order two, one for each end.
                The balun's are just some resistors, so you don't have to get expensive ones.
                Kevin D.
                • yellowfin342
                  • 12
                  Thanks Kevin
                  Yes, I could do that but the computer /projector are in one room and the sound distribution system in another. The two are " connected " via Cat5E Network. I could run a coaxial wire on the floor for each movie we watch, then disconnect it when the movie was over but I am exploring other possibilities maybe using the network or the Cat5e wiring.
                  I think I can get it to work using VLC and its server function but that does not play BluRay so far as I know.
                  The receiver I am looking at Denon4308ci and 3808ci have network connections and IP addresses which can receive codecs. I guess I am looking for a player that can send audio to the receiver over the network, like VLC does, but also plays BluRay. I am checking to see if I can rip the Bluray Disc to ISO file and then get VLC to play it. I rip to ISO all the time so it's a matter of trying to get VLC to play it.
                  BTW, if you have another recommendation on receiver or separates in the same $ range, I am all ears !
                  Thanks Again, Its all very interesting and I am learning a lot
                    Kevin:
                    I'd like to hear more about what you know regarding HDMI over Cat 5. The biggest reason I've been investigating the technology is my own house, which currently distributes video throughout the home over RG-6 coax composite. I want to go full digital HD video distribution, so 1080p HDMI. My limitations are the house pre-wiring, which has RG-6, Cat 5 telephone, and Cat 5 network jacks run to multiple panels throughout the house. (from the house's central equipment room) Each room in the house has 1-2 of the panels. So the best solution for me is to distribute HDMI through the available Cat-5 runs. Although it would be possible for me to do it over two Cat-5 runs, (i.e. to two jacks in the room, and then run a patch cable from the far jack to the actual video display, or by hijacking the Cat-5 telephone run) the most straightforward solution is just HDMI over single Cat-5.
                    So what's this about Cat-5 solutions not working? And are you saying that single Cat 5 extenders lmiit the resolution? The companies are still claiming full 1080p, even HDMI 1.3. The companies I know of, with single Cat-5 are Gefen, Atlona, and... shoot, can't remember the 3rd offhand.
                    • yellowfin342
                      • 12
                      If I had a computer in the room where the receiver is located, a media room, and another computer where the projector is located, then could I use Windows media center in the first computer to send audio to the receiver and video to the second computer where the projector was located ?
                      That seems pretty straightforward.
                      bill
                      • sanaka
                        video over UTP/cat5 cable
                        by sanaka
                        Hi.
                        I'm building a new house and plan to run in-wall wiring to a projector location.
                        I found some cool RCA and S-Video modular wall jacks that terminate via 110 punchdown blocks. The idea being to directly run these signals on Cat cable.
                        But will this really...
                        01 February 2006, 07:28 Wednesday
                      • yellowfin342
                        streaming audio via cat5 network to receiver or separates
                        by yellowfin342
                        Hello All
                        I would like to ask if anyone knows if it is possible to play Blu ray Movie in Computer with BluRay Player, out put video to Projector, and then send Audio to Receiver or Separates via Cat5e network. I am looking at Denon 4808CI but any good one would do.
                        With the current...
                        28 December 2008, 13:41 Sunday
                      • ekkoville
                        A/V over Cat5
                        by ekkoville
                        I have seen options of running A/V over Cat5 wire to some remote locations in the house and wonder if anyone has had experience with that or has an opinion on it. It seems some shielding could be lacking with the wire, but for long runs through conduit it is lot easier. There are many whole house options...
                        16 May 2005, 08:50 Monday
                      • pbone
                        Computer sound card, SPDIF and the RSX-1055
                        by pbone
                        I need a sound card with AC3 pass through and SPDIF out. As far as I can gather my current sound card (sound blaster live value) can't do this. I gather the Sound Blaster Live 5.1 can do it, although apparently its digital output voltage is considerably higher than the SPDIF standard. Creative claims...
                        13 April 2003, 14:28 Sunday
                      • rofafor
                        Rotel 1068 & nonstandard SPDIF streams
                        by rofafor
                        There're some old SPDIF devices (like AV7110-based DVB-cards found in many HTPCs) that cannot set the non-linear status bit in the SPDIF stream. In these cases the AV-receiver/processor itself has to analyse the PCM data in the SPDIF stream and switch on the DD/DTS decoder, if a DD/DTS stream is detected....
                        12 December 2004, 11:50 Sunday
