channel output problem
  • jackthestreet
    • Dec 2011
    Happy new year everybody :
    I am new to this forum.
    I recently bought on ebay a Rotel 840BX4 integrated amplifier. It works find when I use the cd input. However, I have a problem with either AUX input. I use the AUX to connect my tv receiver and my computer. After 5 to 10 minutes one channel suddenly stops, it produces some glitches for a while and then seems to completely die. Then, when I switch on a cd both channels work fine.
    I guess there is some overheating somewhere or may be an other problem ?
    I tried to find a schematics on the web with no success.
    Can somebody could give me some clues on the parts to check ?
    thanks
  • madmac
    • Aug 2010
    • 3122
    First off, check your wires to be sure that's not the issue by switching them out. If that's not the issue, unplug the unit and pop off the lid and look at the inputs in question. Clean them and re-solder if necessary. Honestly, this does not sound like a serious problem at all since it works with the CD input.
    Dan Madden :T
    • pvabeach
      Trigger and problem with Input modes
      by pvabeach
      The 12 v trigger only works if zone 2 is off!!!
      On another topic. I have dishnetwork with dobly digital optical connection to 1066. I have set default mode to dobly digital II as most programming is PCM vs dobly digital.
      I've noticed that 1066 will switch to dobly digital EX mode when...
      18 August 2002, 11:04 Sunday
    • zeze22
      ..for the techies - DAC into Zeppelin Class-D aux port?
      by zeze22
      Given that the B&W Zeppelin has a Class D amp with an optical input, would it make sense to run a MF V-Dac between an airport express and the Zep's aux port?
      No DAC: Airport Express digital runs direct into the digital amp.
      DAC: AX converted to digital via DAC and then...
      15 January 2010, 19:08 Friday
    • slayer
      Question about AUX outputs for a Rear Sub.
      by slayer
      My question is about programming for a rear sub. I have my front/main sub hooked up to the LFE/sub preout. No problems here. I have another sub in the back of my room and it is hooked up to the AUX 2 output to mimic the main sub. No problems here.
      I want to try my rear sub as a dedicated rear...
      01 January 2006, 16:54 Sunday
    • bsodmike
      Denon AVR-3805, Mixing Input Sources...
      by bsodmike
      Hiya,
      Atm I got my 360 connected to VDP and have set the video to Composite source 1, and audio to one of the opt interfaces. I have my computer connected to COAX1.
      How can I listen to the 360 and the computer at the same time? (mix both inputs?). That said, it doesn't...
      13 September 2006, 16:35 Wednesday
    • oxcartdriver
      HDMI connectivity problem, Integra DTC 9.8 w/ Sony BDP-s350
      by oxcartdriver
      I'm having connectivity problems with my Integra DTC 9.8 and Sony BDP-S350 using an HDMI connection.
      S350 is setup as DVD, HDMI input #2
      Comcast box setup as CBL/Sat, HDMI input #1
      Signature:
      Sony BDP-S350 will not show video or voice when connected through...
      28 July 2008, 13:23 Monday
