Trigger and problem with Input modes
  • pvabeach
    • 10
    The 12 v trigger only works if zone 2 is off!!!
    On another topic. I have dishnetwork with dobly digital optical connection to 1066. I have set default mode to dobly digital II as most programming is PCM vs dobly digital.
    I've noticed that 1066 will switch to dobly digital EX mode when it sees doby digital (vs pcm) signal from dish, which is great. However, when you change channels, 1066 goes back to pcm audio for all none dobly digital channels. It does not switch back to dobly digital II despite designating input default as dolby digital II (i'm using cinema mode). Anyone else notice this? Software bug?? Paul
  • pbarata
    Which delay for Dolby Digital on RSP-1066?
    by pbarata
    I’ve recently moved my surround speakers and now I have a higher distance from listening position then before.
    After making some measures and calculations I end up with a suggested delay of 3 ms for Dolby Digital.
    Unfortunately RSP-1066 only accepts increments of 5 ms,...
    30 November 2005, 06:23 Wednesday
  • [c]oma
    RSX-1055: Dolby Digital 2.0 passthrough over SPDIF not working
    by [c]oma
    I currently have my PC connected to my amp (Rotel RSX-1055) via an SPDIF connection to the Coaxial 1 input. I am using a Creative X-fi ExtremeMusic card and I am running windows XP x64 professional. Everything including drivers has been updated to the most recent versions. I have a stereo setup at the...
    17 March 2009, 08:03 Tuesday
  • keiron99
    Digital throughput on 1066
    by keiron99
    I hope I can explain this clearly:
    I have acquired a DAC for my hifi which I want to use for my stereo music listening as it provides higher quality replay than the 1066. I will connect my source to the DAC digitaly, then connect the lineouts of the DAC to the 1066 (in effect just using...
    21 December 2005, 12:05 Wednesday
  • Dan K
    RSX-1056 having problem switching dolby digital
    by Dan K
    hey everyone,
    i've been having a problem with my 1056 receiver and my dealer has no solution for me. i'm hoping somebody here might have an answer.
    i have a time warner cable hd dvr cable box.
    sometimes when i am watching a station in dobly digital and then...
    11 September 2005, 19:07 Sunday
  • gshisme
    Optical vs. coaxial digital for the 1066
    by gshisme
    I have been using digital optical cable for both my DVD and HDTV satellite receiver to connect to the 1066 and my dealer yesterday told me to throw away my optical for coaxial. Huh? Everything I have read points me to optical cable. Any comments on optical vs. coaxial cable use.
    Greg...
    26 May 2003, 13:31 Monday
