serial cable for firmware upgrade
Tags: None
I am under the impression that it is a proprietary wiring scheme and you will either need the Rotel cable or will need to DIY one.
Here is an HTGuide thread that explains it.
Kevin D (Moderator) would probably know if this is correct or maybe even where a Rotel cable could be sourced.
Steve- Bottom
The cable part # is CB00004 and it can be ordered by contacting Rotel Technical Support at 978-664-2870.
The pin configuration for this cable is available here (PDF): Rotel RJ45 to DB9 Cable Pin Configuration Diagram
Source: http://bwgroup-support.com/rotelsetup.html- Mike
Main System:
B&W 802D, HTM2D, SCMS
Classé SSP-800, CA-2200, CA-5100- Bottom
Thanks! Any idea how much the cable costs from Rotel? @#$%^& non-standard wiring, BTW. I googled up the pin connections for the Cisco cable, and indeed they are different.Originally posted by mjbThe cable part # is CB00004 and it can be ordered by contacting Rotel Technical Support at 978-664-2870.
Source: http://bwgroup-support.com/rotelsetup.html- Bottom
First question, does this unit provide the verbose feedback that other Rotel units do? I'd love feedback on volume status, input selection etc.
I am trying to control it with Crestron and having problems. I am not sure if the problem is my hacked together cable or the serial strings...-
Channel: Club Rotel
by punks123Can someone please help me with updating the DSP firmware for the rotel 1560? I was able to flash the main board and video to the lastest firmware on the bwgroupsupport. I checked the version on the audio firmware it show 00.00000000. I got this receiver from some one and was not aware if the sound...-
Channel: Club Rotel
by mkeddaHello.
I am trying to upgrade the Rotel RSP-1069 with the latest firmware obtained from Rotel.
I have the official cable from Rotel.
I am using Windows XP.
I have a serial port on the laptop.
I activated firmware upgrade in the rotel menu system....-
Channel: Club Rotel
by chamathI would like to share my 2nd upgrade experience with you so hopefully you would not run into the same issues I had. I have a Rotel RSX-1057; however, the issue described below would apply to any upgrade as it was not a Rotel problem.
Firmware: (1057)
my system = 2.1.2
Channel: Club Rotel
by TommyVOK I would like to hear from people who have successfully used a USB to serial adapter/converter cable to update the firmware on their 10 or 15 series processor or AVR. I want to be able to use my laptop to do this update which is Vista 64bit. I am trying to update my RSP-1069
hifiguy...-
Channel: Club Rotel
- Loading...
- No more items.
