Please help me with DSP firmware update for rotel 1560
  • punks123
    • Sep 2013
    • 4
    Can someone please help me with updating the DSP firmware for the rotel 1560? I was able to flash the main board and video to the lastest firmware on the bwgroupsupport. I checked the version on the audio firmware it show 00.00000000. I got this receiver from some one and was not aware if the sound was working properly or not. I used both windows 7 32 bit and currently on Windows xp sp3 but it keep saying failed the dsp response after 7-8 seconds every times I connect to the rotel to flash the firmware the the unit just freeze up. I set my comp port to 1 and baud rate 115200, i tried different port but it the same result. I did try different cat5 cable and usb=>serial, currently using the belkin serial==>usb.
  • punks123
    • Sep 2013
    • 4
    Send it back to rotel for service... 5 years warranty is still good
      Did your dealer look at it before it went back??
      • punks123
        • Sep 2013
        • 4
        Nope... I just explained the problem to the tech and he said it was a common problem for that model. He asked me to fill out the paperwork and said it will likely take a month for everything.
        • punks123
          • Sep 2013
          • 4
          I used hdmi, coaxial, optical, composite but did not get any sound output..
          • Miguel
            RSX 1560 firmware upgrade - help needed!
            by Miguel
            Hi everybody,
            I'm in the process of upgrading the firmware on my RSX1560 after obtaining the links and instructions from Rotel. This upgrade comes in 3 parts, main, video scaler and audio. Interestingly enough, there are 2 different computer programs that you use to flash the 1560 -...
            11 August 2009, 00:06 Tuesday
          • Iggurk
            RSP-1098 Firmware 2.20
            by Iggurk
            Hello!
            Firmware 2.20 if anyone interested to upgrade.
            2.18 -> 2.19
            only a small display issue (no PrLogic Icon when playing 2CH PCM source)
            2.19 -> 2.20
            1 PCM2CH, 176K/192K support. When it is 176.4/192K, Temporary G.Delay, Tone can't...
            18 January 2007, 17:57 Thursday
            Firmware update changes.
            by Andrew Pratt
            RSP 1098 Software Updates Release Notes
            V1.0.0 to V1.1.0 - Allowed a press of the function knob on front panel to power unit on from Standby. - Software relating to the MP3 decoding was changed. - Test Tone level reduced from -23dbfs to -30dbfs per Dolby spec. - Fixed lack of video output...
            22 February 2005, 15:07 Tuesday
          • sajib
            RSP-1570 No Audio after firmware upgrade
            by sajib
            Hi There,
            Seeking out for advise before i take my unit for servicing, just upgraded my Rotel RSP 1570 unit from a grandfather firmware (v 1.0) to V1.28
            update for main unit and video went all fine and everything was working as normal, couldn't update the DSP at first with...
            25 April 2014, 06:39 Friday
            Firmware revision documention
            by Andrew Pratt
            Guess what Rotel sent me this morning!
            Note that the HD units indicates the newer models running the modified chipsets. If your machine is using these different chipsets please do not flash your firmware unless you've obtained the correct file directly from Rotel.
            RSP 1066 Software...
            30 October 2002, 13:14 Wednesday
